[GRASS-dev] Possible bug in r.out.gdal?
Dear Devs,
i found a strange behavior in r.out.gdal while updating the GRASS test suite.
Im using the grass6.4svn snapshot: grass-6.4.svn_src_snapshot_2009_08_01.tar.gz.
on openSuse 10.3 Linux 2.6.22.19-0.2-bigsmp
gdal version 1.6.1
The test i am implementing tries to export a DCELL raster map (named elevation ) to a DTED file with r.out.gdal.
r.out.gdal reports plenty of errors (all of the same type) an exits with return code 0.
A dted file is created, but im not sure if it is valid.
Exporting the same file with r.out.gdal in ENVI and ELAS formats seems to work correctly.
These steps are performed:
GRASS 6.4.0svn > g.region -p
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5582000
south: 5580000
west: 400000
east: 402000
nsres: 20
ewres: 20
rows: 100
cols: 100
cells: 10000
GRASS 6.4.0svn > r.info elevation
| Layer: elevation Date: Sun Apr 30 12:48:58 2006 |
| Mapset: PERMANENT Login of Creator: soeren |
| DataBase: /1/gebbert/src/GRASS_Testsuite |
| Title: ( elevation ) |
Timestamp: none
Type of Map: raster Number of Categories: 255
Data Type: DCELL
Rows: 100
Columns: 100
Total Cells: 10000
Projection: UTM (zone 32)
N: 5582000 S: 5580000 Res: 20
E: 402000 W: 400000 Res: 20
Range of data: min = 68.246322 max = 363.529491
Data Description:
generated by r.mapcalc
Comments:
sin(col() * 5) * col() + cos(row() * 5) * row() + 200
GRASS 6.4.0svn > r.out.gdal --verbose format=DTED type=Float32 input=elevation output=/tmp/test.dted
ERROR 5: Access window out of range in RasterIO(). Requested
(0,994) of size 201x1 on raster of 100x100.
(0,995) of size 201x1 on raster of 100x100.
(0,996) of size 201x1 on raster of 100x100.
More than 1000 errors or warnings have been reported. No more will be reported from now.
r.out.gdal complete.
GRASS 6.4.0svn > gdalinfo -nomd -noct -stats /tmp/test.dted
Driver: DTED/DTED Elevation Raster
Files: /tmp/test.dted
/tmp/test.dted.aux.xml
Size is 201, 1201
Coordinate System is:
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]]
Origin = (399.997500000000002,559.000416666666638)
Pixel Size = (0.005000000000000,-0.000833333333333)
Corner Coordinates:
Upper Left ( 399.998, 559.000) (399d59’51.00"E,559d 0’1.50"N)
Lower Left ( 399.998, 558.000) (399d59’51.00"E,557d59’58.50"N)
Upper Right ( 401.002, 559.000) (401d 0’9.00"E,559d 0’1.50"N)
Lower Right ( 401.002, 558.000) (401d 0’9.00"E,557d59’58.50"N)
Center ( 400.500, 558.500) (400d30’0.00"E,558d30’0.00"N)
Band 1 Block=1x1201 Type=Int16, ColorInterp=Palette
Min=0.000 Max=0.000
Minimum=0.000, Maximum=0.000, Mean=0.000, StdDev=0.000
NoData Value=-32767
Unit Type: m
Color Table (RGB with 365 entries)
Any suggestions what i did wrong?
Maybe the region settings are incompatible with the dted output coordinate system?
Or is this a correct behavior of r.out.gdal?
Thanks in advance
best regards
Soeren
Soeren Gebbert wrote:
Dear Devs,
gdal version 1.6.1
Using grass6.4svn with gdal1.6.0 here
Exporting elevation from nc_spm_08 with
r.out.gdal input=elevation@PERMANENT format=DTED type=Float32 output=test.dted
gives me
Driver <DTED> does not support direct writing. Using MEM driver for
intermediate dataset.
Exporting to GDAL data type: Float32
100%
Warning 1: The source does not appear to be a properly formatted cell.
Warning 1: The source projection coordinate system is PROJCS["Lambert Conformal Conic",GEOGCS["grs80",DATUM["North_American_Datum_1983",SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["standard_parallel_1",36.16666666666666],PARAMETER["standard_parallel_2",34.33333333333334],PARAMETER["latitude_of_origin",33.75],PARAMETER["central_meridian",-79],PARAMETER["false_easting",609601.22],PARAMETER["false_northing",0],UNIT["Meter",1]]. Only WGS 84 is supported.
The DTED driver will generate a file as if the source was WGS 84 projection coordinate system.
Warning 1: The corner coordinates of the source are not properly aligned on plain latitude/longitude boundaries.
Warning 1: The horizontal source size is not conformant with the one expected by DTED Level 1 at this latitude (1500 pixels found instead of 225).
projection: 1 (UTM)
At least in gdal1.6.0, only WGS84 is supported for DTED, see warning above. WGS72 is also supported, but the gdal driver issues a warning.
GRASS 6.4.0svn > r.out.gdal --verbose format=DTED type=Float32 input=elevation output=/tmp/test.dted ....
These messages are generated by gdal, not r.out.gdal. See
http://www.gdal.org/frmt_dted.html
for more info on the DTED format, particularly the section Creation Issues and the link to the DTED specs:
http://www.nga.mil/ast/fm/acq/89020B.pdf
If you can confirm that the input data are exactly formatted as Level 0, 1 or 2 cell, it is a problem of r.out.gdal. Also note that for DTED, elevation data is returned as 16 bit signed integer (citation from gdal).
hope that helps,
Markus M
From the DTED specs:
A data file of DTED Level 0, DTED Level 1 or
DTED Level 2 is a 1° by 1° cell defined by whole degree latitude and
longitude
lines on WGS. A DTED file shall not cross whole degree latitude or longitude
lines.
Matrix intervals for DTED Level 0.
ZONE LATITUDE latitude x longitude INTERVAL
I 0° - 50° North-South 30 x 30 seconds
II 50° - 70° North-South 30 x 60 seconds
III 70° - 75° North-South 30 x 90 seconds
IV 75° - 80° North-South 30 x 120 seconds
V 80° - 90° North-South 30 x 180 seconds
Matrix intervals for DTED Level 1.
I 0° - 50° North-South 3 x 3 seconds
II 50° - 70° North-South 3 x 6 seconds
III 70° - 75° North-South 3 x 9 seconds
IV 75° - 80° North-South 3 x 12 seconds
V 80° - 90° North-South 3 x 18 seconds
Matrix intervals for DTED Level 2.
I 0° - 50° North-South 1 x 1 seconds
II 50° - 70° North-South 1 x 2 seconds
III 70° - 75° North-South 1 x 3 seconds
IV 75° - 80° North-South 1 x 4 seconds
V 80° - 90° North-South 1 x 6 seconds
No idea how strict the gdal driver for DTED is, but it seems that it is
very strict and won't work without reprojection, followed by setting
region extends and resolution according to the desired DTED level.
Markus M
Dear Devs,
gdal version 1.6.1
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5582000
south: 5580000
west: 400000
east: 402000
nsres: 20
ewres: 20
rows: 100
cols: 100
cells: 10000
GRASS 6.4.0svn > r.info <http://r.info> elevation
| Timestamp: none |
| Type of Map: raster Number of Categories: 255 |
| Data Type: DCELL |
| Rows: 100 |
| Columns: 100 |
| Total Cells: 10000 |
| Projection: UTM (zone 32) |
| N: 5582000 S: 5580000 Res: 20 |
| E: 402000 W: 400000 Res: 20 |
| Range of data: min = 68.246322 max = 363.529491 |
| Data Description: |
| generated by r.mapcalc |
| Comments: |
| sin(col() * 5) * col() + cos(row() * 5) * row() + 200 |
Size is 201, 1201
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563]],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Corner Coordinates:
Upper Left ( 399.998, 559.000) (399d59'51.00"E,559d 0'1.50"N)
Lower Left ( 399.998, 558.000) (399d59'51.00"E,557d59'58.50"N)
Upper Right ( 401.002, 559.000) (401d 0'9.00"E,559d 0'1.50"N)
Lower Right ( 401.002, 558.000) (401d 0'9.00"E,557d59'58.50"N)
Center ( 400.500, 558.500) (400d30'0.00"E,558d30'0.00"N)
  Min=0.000 Max=0.000
  NoData Value=-32767
  Unit Type: m
Thanks in advance
best regards
Soeren
grass-dev mailing list
grass-dev@lists.osgeo.org
Hello Markus,
many thanks for your response.
I guess the behavior of r.out.gdal in case of a raster map in UTM projection and DTED export seems to be correct.
So i removed the DTED test from the GRASS testsuite, based on your suggestions and the gdal documentation.
soeren
2009/8/11 Markus Metz <markus.metz.giswork@googlemail.com>
longitude
lines.
very strict and won’t work without reprojection, followed by setting
Markus M
Dear Devs,
gdal version 1.6.1
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5582000
south: 5580000
west: 400000
east: 402000
nsres: 20
ewres: 20
rows: 100
cols: 100
cells: 10000
Timestamp: none
Data Type: DCELL
Rows: 100
Columns: 100
Total Cells: 10000
Data Description:
Comments:
GRASS 6.4.0svn > r.out.gdal --verbose format=DTED type=Float32 input=elevation output=/tmp/test.dted …
Size is 201, 1201
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Corner Coordinates:
Min=0.000 Max=0.000
NoData Value=-32767
Unit Type: m
Thanks in advance
best regards
Soeren
Soeren wrote:
| Data Description:
nice test pattern
H
Hello Markus,
To be precise, it's the behaviour of the gdal library. r.out.gdal leaves the format-specific tests to the gdal library, and it was the gdal library, not r.out.gdal, that issued the ERROR 5: messages. There is nothing that can be done in r.out.gdal to avoid this kind of error.
Markus M
soeren
2009/8/11 Markus Metz <markus.metz.giswork@googlemail.com <mailto:markus.metz.giswork@googlemail.com>>
    longitude
    longitude
    lines.
    it is
    Markus M
        Dear Devs,
        GRASS test suite.
        gdal version 1.6.1
        projection: 1 (UTM)
        zone: 32
        datum: wgs84
        ellipsoid: wgs84
        north: 5582000
        south: 5580000
        west: 400000
        east: 402000
        nsres: 20
        ewres: 20
        rows: 100
        cols: 100
        cells: 10000
        GRASS 6.4.0svn > r.info <http://r.info> <http://r.info> elevation
         | Layer: elevation Date: Sun Apr 30
        12:48:58 2006 |
         | Mapset: PERMANENT Login of Creator:
        soeren |
         | DataBase: /1/gebbert/src/GRASS_Testsuite |
         | Title: ( elevation ) |
         | Timestamp: none |
         | Type of Map: raster Number of Categories:
        255 |
         | Data Type: DCELL |
         | Rows: 100 |
         | Columns: 100 |
         | Total Cells: 10000 |
         | Projection: UTM (zone 32) |
         | N: 5582000 S: 5580000 Res: 20 |
         | E: 402000 W: 400000 Res: 20 |
         | Range of data: min = 68.246322 max = 363.529491 |
         | Data Description: |
         | generated by r.mapcalc |
         | Comments: |
         | sin(col() * 5) * col() + cos(row() * 5) * row() + 200 |
        Size is 201, 1201
        GEOGCS["WGS 84",
           DATUM["WGS_1984",
        Corner Coordinates:
        0'1.50"N)
        0'1.50"N)
         Min=0.000 Max=0.000
         NoData Value=-32767
         Unit Type: m
        Thanks in advance
        best regards
        Soeren
        grass-dev@lists.osgeo.org <mailto:grass-dev@lists.osgeo.org>
