[GRASS-dev] Possible error in r.flow error message
I have tested r.flow looking for messages to standardize. I gave a non existing input elevation raster map, so I waited "Cannot find file %s" but error message is "out of memory". Is it the right behaviour? Does it check memory before looking for the input map? If so, why doesn't it get memory?
I thank any help.
Carlos
memory?
that is certainly not a right behavior - let me look at it, Helena
I thank any help.
Carlos
grass-dev mailing list
grass-dev@grass.itc.it
memory?
are you sure the file that you gave it was indeed non-existing?
I tried it and it gave me the right message:
GRASS 6.3.cvs > r.flow elevin=junk dsout=dsdtest
Reading input files: elevation
ERROR: Cannot find file junk
Helena
I thank any help.
Carlos
Helena
Yes, sure.
GRASS 6.3.cvs (Extremadura_h29):~ > r.flow elevin=junk dsout=dsdtest
ERROR: G_calloc: sin memoria (out of memory)
May be I need to make distclean, but I have no time now to recompile. Send result later.
Carlos:
Yes, sure.
Send result later.
I too get:
maybe some hints if run with DEBUG=5 ?
Hamish
Helena
Yes, sure.
Still the same problem after make distclean and cvs update.
Hamish escribió:
Carlos:
  Yes, sure.
I too get:
Just the same result:
GRASS 6.3.cvs (Extremadura_h29):~ > DEBUG=5
