[GRASS-dev] possible error in WIKI could cause data corruption
I don’t know if this is bad advice in the GRASS WIKI or a bug in a GRASS database module. I have some vector files that were somehow imported into a dbf DBMS last year. I wanted to switch them all to sqlite. The GRASS WIKI advises…
Convert automatically all GRASS 6 vector maps to GRASS 7 (including attribute transfer from DBF to SQLite)
To become readable in GRASS 7, all vector maps in a mapset need to be updated to the improved vector file format (i.e., rebuild the topology with v.build.all along with the change to the SQLite database backend (SQLite is the new default in GRASS 7 instead of DBF in GRASS 6, using db.connect and v.db.reconnect.all).
Run this in GRASS GIS 7:
first rebuild topology for all vector maps in current mapset
v.build.all
define new default DB connection (switch from DBF to SQLite)db.connect -d
transfer all attribute tables from DBF to SQLite and clean old DBF tablesv.db.reconnect.all -cd
The vectors already had GRASS 7 topology, but I ran v.rebuild.all just to be sure. No problem.
db.connect -d ran with no problem
But v.db.reconnect.all -cd did not create tables in the sqlite database and corrupted the existing connection of the first table it hit. Fortunately, I made a backup of the mapset before I started this.
GRASS 7.1.svn (Spain_fieldwork_medlands_ERTS89_Z30):~ > v.db.reconnect.all -cd
Reconnecting vector map catastro@surveyboundaries (1 of 9)…
Copying table to target database…
File “/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/scripts/db.droptable”, line 99, in
main()
File “/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/scripts/db.droptable”, line 77, in main
used = grass.db.db_table_in_vector(table)
File “/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/etc/python/grass/script/db.py”, line 184, in db_table_in_vector
from vector import vector_db
ImportError: No module named vector
ERROR: Unable to drop table
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sat, Sep 5, 2015 at 7:51 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
advises…
https://grasswiki.osgeo.org/wiki/Convert_all_GRASS_6_vector_maps_to_GRASS_7
sure. No problem.
But the sqlite file is there?
Perhaps a problem on Mac?
This is strange - I have converted so many mapsets like that ..., even
with lots of vector maps inside.
The wiki page is there for a long time, I didn't see such reports so far.
-cd
Reconnecting vector map <catastro@surveyboundaries> (1 of 9)...
Copying table <catastro> to target database...
  File
"/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/scripts/db.droptable",
line 99, in <module>
    main()
  File
line 77, in main
  File
"/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/etc/python/grass/script/db.py",
Maybe something got broken in GRASS 7.1?
I would definitely use 7.0 for such operations.
ERROR: Unable to drop table <catastro>
Michael
____________________
C. Michael Barton
advises…
Convert all GRASS 6 vector maps to GRASS 7 - GRASS-Wiki
sure. No problem.
yes
I had to make a new mapset and then copy the files from the old mapset to the new one. All went into sqlite fine that way.
-cd
File
   main()
File
line 77, in main
File
I’ll check
Michael
Michael
C. Michael Barton
So I decided to try this with 7.0 and looked again at the mapset. It turns out that the folder is there but not the sqlite.db.
So perhaps we need to add to the WIKI that you might need to create the sqlite.db
However, when I tried to create the database, it doesn’t seem to work.
db.createdb driver=sqlite database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
dbmi: db_create_database() not implemented
No error. Just no database.
Michael
C. Michael Barton
advises…
sure. No problem.
-cd
File
   main()
File
line 77, in main
File
Michael
C. Michael Barton
To my knowledge GRASS is designed to generate the file automatically, so the absence in your car is a bug.
I never used that for above mentioned reason…
Michael
C. Michael Barton
advises…
sure. No problem.
This is strange - I have converted so many mapsets like that …, even
The wiki page is there for a long time, I didn’t see such reports so far.
-cd
File
line 99, in
main()
File
line 77, in main
File
Michael
C. Michael Barton
I just remembered a change in trunk (see below):
  File
    main()
  File
line 77, in main
  File
I checked the changes to be backported (still I would appreciate that
the respective devs take care themselves):
On Mon, Aug 17, 2015 at 1:47 PM, <svn_grass@osgeo.org> wrote:
Author: zarch
Date: 2015-08-17 04:47:30 -0700 (Mon, 17 Aug 2015)
New Revision: 65947
Modified:
   grass/trunk/lib/python/script/db.py
Log:
script.db: Fix absolute import inside function
Modified: grass/trunk/lib/python/script/db.py
--- grass/trunk/lib/python/script/db.py 2015-08-17 08:29:14 UTC (rev 65946)
+++ grass/trunk/lib/python/script/db.py 2015-08-17 11:47:30 UTC (rev 65947)
@@ -181,7 +181,7 @@
     :param str table: name of table to query
- from vector import vector_db
+ from .vector import vector_db
     nuldev = file(os.devnull, 'w')
     used =
     vects = list_strings('vect')
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
If your local GRASS 7.trunk version is newer than 2015-08-17,
- maybe r65947 is causing the issue
else
- maybe r65947 is solving the issue
