[GRASS-dev] possible memory leak in Nget_viewdir_cmd ()?
  togl_flythrough.c reads:
--cut: http://svn.osgeo.org/grass/grass/trunk/visualization/nviz/src/togl_flythrough.c--
   901 int Nget_viewdir_cmd(Nv_data * data, Tcl_Interp * interp, /* Current interpreter. */
   902 int argc, /* Number of arguments. */
   903 char **argv /* Argument strings. */
   904 )
   905 {
   920 Tcl_SetResult(interp, Tcl_Merge(3, list), TCL_VOLATILE);
   921
   922 return (TCL_OK);
   923 }
  However:
--cut: Tcl_Merge(3tcl)--
      Tcl_Merge is the inverse of Tcl_SplitList: it takes a collection
      of strings given by argc and argv and generates a result string
      that has proper list structure. [...]
      The result string is dynamically allocated using Tcl_Alloc; the
      caller must eventually release the space using Tcl_Free.
  Hence, it seems that TCL_DYNAMIC is to be used instead of the
  current TCL_VOLATILE.
