[GRASS-dev] Possible typos error in ./general/manage/cmd/rename.c:103
I think there may be an error in ./general/manage/cmd/rename.c:103 (Renaming in reclassed map%s), but not sure the right form (¿map %s, mapset?)
Carlos
G_message(_("Renaming in reclassed map%s"),
    (nrmaps > 1 ? "s" : ""));
if there is more than 1 map it adds an "s" to the end of the string.
this sort of pluralization trick is probably not very transaltion safe,
and should be avoided. Beyond that, I'm not really sure what that
message is trying to say.
Hamish
The "in" is a grammatical error; I've changed that line to:
  G_message(_("Renaming reclass maps"));
It's usually better to just always use the plural in such situations
than adding a special case for n == 1.
