[GRASS-dev] PostGIS manager for GRASS GIS
Hello all,
I am interested in making a PostGIS manager in GRASS as a GSoc 2012 task.
PyGreSQL is a python module that allows easy use of database operation API from a pyhton script. So it will be like a wrapper over
the database. This can be done using wxPython and will be OS independent.
Sorry to bug you all, but I am very much interested in developing for GRASS.
Is anybody willing to mentor ?
Looking forward to your support.
Thanks and Regards,
Mohit Kumar
Lab For Spatial Informatics
International Institute of Information and Technology
Hyderabad, India
+9.1-9.7.0.3.8.4.0.1.7.5.
Hello Mohit Kumar,
On Tue, Mar 27, 2012 at 2:25 PM, Mohit Kumar
<mohit.kumarug08@students.iiit.ac.in> wrote:
Hello all,
there is new development ongoing for this in GRASS 7, perhaps a good
moment to integrate a manager. Maybe Martin has some insights for
us over the next days.
Hello sir,
On Sat, 31 Mar 2012 23:11:04 +0200, Markus Neteler wrote:
Hello Mohit Kumar,
Hello all,
Thanks for your reply.
Its good to know that development is ongoing for this in GRASS, I sincerely want to work on this as my GSoc task.
I have made a brief idea for the manager. The following are the various modules of the manager
1. Setup connection : This module will set up the connection with the remote database. It will take the input parameters from user and pass them to a connection string. After the connection has been established, the user will be shown the various tables(maps) that are stored and other information about the database and the connection
2. View and edit data : This will display the data of the table in a window frame. One can view the map and modify the table values or the attributes.
3. Import to GRASS Data : This gives the user an option to save the data in Grass format for further processing/analysis of the data. This also gives user an option to discard the data which is of no use.
4. Execute PostGis functions (geometry processing)on database and save output in grass data format.
5. SQL interface : This provides the advanced user to modify the database by use of direct SQL commands on the database.
6. Export GRASS data to PostGIS data : Convert the Grass Data to SQL database. First convert the Grass data to Esri Shapefile(.shp) using OGR and then converting that data to SQL database (shape2sql).
7. Projection support : I was also thinking of adding projection support to the manager.
These are the various major points for a spatial database manager I can think of. Can you please provide me your suggestions.
Looking forward to your support as the time left to apply is very less.
Mohit Kumar(mohitkharb on irc)
Hyderabad, India
+91-970-3840-175
On 04/02/2012 05:11 PM, Mohit Kumar wrote:
[snip]
attributes.
Since the PostGIS data model is much more flexible than a Shapefile:
Why not directly convert the GRASS data to PostGIS WKB/WKT?
Ben
to the manager.
Hyderabad, India
+91-970-3840-175
grass-dev mailing list
grass-dev@lists.osgeo.org
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
   benducke@fastmail.fm
2012/4/2 Mohit Kumar <mohit.kumarug08@students.iiit.ac.in>:
API
GRASS.
the current PostGIS-related development in G7 is not much related to
this idea. The vector engine in G7 is currently able to read PostGIS
geometry data natively without any abstract level (like OGR-PostgreSQL
driver). Also write support has been recently implemented. The current
implementation is focused on simple feature access, GRASS builds a
pseudo-like topology as for OGR links (see v.external). At this moment
I am working on PostGIS topology support in GRASS.
This is already available in wxGUI [1]. Of course there is always a
space for any kind of improvements. But basically it's already there,
to add widgets for entering username and password is quite easy task.
Also possible in current wxGUI [2]. You just create a link using
`v.external` and display the map in the map canvas as normal GRASS
vector map. Also direct OGR access [3] is possible (no links,
pseudo-topology built on the fly)
Possible with `v.in.ogr`. Simple wrapper based `v.in.ogr` for
importing PostGIS is already there [4].
This could be improvement.
Why?? You can export data directly using `v.out.ogr` [5]. No need for
Shapefiles, that's bad idea.
the manager.
In which sense, do you mean on-the fly re-projection (ST_transform)?
Martin
[1] http://grass.osgeo.org/wiki/Working_with_external_data_in_GRASS_7#Using_wxGUI
[2] http://grass.osgeo.org/wiki/Working_with_external_data_in_GRASS_7#Digitize_OGR_layer_using_wxGUI
[3] http://grass.osgeo.org/wiki/Working_with_external_data_in_GRASS_7#Direct_access_to_external_data
[4] http://grass.osgeo.org/wiki/PostGIS#Import_into_GRASS
[5] http://grass.osgeo.org/wiki/PostGIS#Export_to_PostGIS
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Hello Martin,
Sorry couldn't reply earlier as I was stuck with some college work.
On Mon, 2 Apr 2012 21:00:51 +0200, Martin Landa wrote:
API
GRASS.
the manager.
Martin
[1]
[2]
[3]
Thanks for your feedback.
I know that various modules are possible in GRASS wxGUI. I want to integrate them all and provide a direct interface for them. Regarding data Export I was thinking about 'v.out.ogr' only.
And I was talking about on-the fly re-projection. The projection tables can be stored in which ever way the user wants.
What more would you like to add to the current idea to make it worth for a GSOC proposal?
Mohit Kumar (mohitkharb on irc)
Hyderabad, India
+91-970-3840-175
Shall I go with this PostGIS manager proposal and apply on melange website?
Any further suggestions are welcome
Only one day is left to appply.
Thanks and regards,
Mohit
On Wed, 04 Apr 2012 01:56:17 +0530, Mohit Kumar wrote:
Hello Martin,
API
GRASS.
the manager.
Martin
[1]
[2]
[3]
Hyderabad, India
+91-970-3840-175
Hyderabad, India
+91-970-3840-175
On Thu, 05 Apr 2012 12:26:19 +0530
Mohit Kumar <mohit.kumarug08@students.iiit.ac.in> wrote:
website?
Hello Mohit,
I'd suggest you to apply on Melange. You will be able to edit the
proposal until the deadline, and exchange further comments during next
two weeks, before student acceptance.
Best,
Anne
Thanks and regards,
Mohit
> Hello Martin,
>> Hi,
>>>>> 2012 task.
>>>>> operation
>>>>> API
>>>>> independent.
>>>>> developing for
>>>>> GRASS.
>>>> good
>>> sincerely
>> to this idea. The vector engine in G7 is currently able to read
>> PostGIS geometry data natively without any abstract level (like
>> OGR-PostgreSQL
>> current
>> moment
>>> various
>>> the remote
>>> them to a
>>> user will
>>> information
>> there,
>> task.
>>> in a window
>>> attributes.
>>> the data in
>>> also gives
>>> save
>>> database by
>>> SQL
>>> using OGR and
>> for
>>> support to
>>> the manager.
>> (ST_transform)?
>> Martin
>> [1]
>> [2]
>> [3]
> Regards,
