[GRASS-dev] potential bug in Location wizard: Choose EPSG Code
Hi ,
We are loading self made pseudo EPSG codes from IAU2000 in the Location Wizard EPSG dialog.
It allows us to load our file, our proj4 description is accepted and the dialog enables the "Next" button.
OK, OnClick the Next button, it tells:
ERROR 6: EPSG PCS/GCS code 19910 not found in EPSG support files. Is this a valid EPSG coordinate system?
ERROR: Unable to translate EPSG code
Yann
Yann Chemin
Address: 3 Toul Melin, 56400 Plumergat
Mobile: +33 (0)7 83 85 52 34
