most of the workflows in my latest PR are queued because of [1]. Any
idea what could be wrong? ubuntu-20.04 is defined in [2].
The first link leads me to “Python Flake8 Code Quality” (flake8), but since you are mentioning ubuntu-20.04, that job (although ubuntu-18.04 too) fails with timeout after 6 hours (GitHub job max time). There are some issues with tests that sometimes they get stuck. I was not able to determine the reason from the results. It always seems to be a different test.
If someone wants to investigate more or add some time checks to gunittest to mitigate this right there that would be great. I can provide reviews or some other help. Adding a time limit (timeout-minutes [1]) to the job would at least resolve the issue of unnecessary job running.
As for the many jobs for PRs being queued, that’s now pretty much standard in times which seem to be Western hemisphere working hours. I think the 20 concurrent jobs limit [2] applies to the whole OSGeo org.
Let me know if this addresses your question or not. Nothing wrong with your code. The jobs are finished or running at the time of writing this email.
pá 10. 12. 2021 v 14:52 odesílatel Vaclav Petras <wenzeslaus@gmail.com> napsal:
As for the many jobs for PRs being queued, that's now pretty much standard in times which seem to be Western hemisphere working hours. I think the 20 concurrent jobs limit [2] applies to the whole OSGeo org.
