I would like to submit following commit to GRASS GIS - master
Index: vector/v.out.ogr/args.c
— vector/v.out.ogr/args.c (revision 71566)
+++ vector/v.out.ogr/args.c (working copy)
@@ -32,7 +32,7 @@
options->format->type = TYPE_STRING;
options->format->required = YES;
options->format->multiple = NO;
options->format->answer = “ESRI_Shapefile”;
options->format->answer = “DPKG”;
options->format->options = OGR_list_write_drivers();
options->format->description = _(“Data format to write”);
any objections?
Reasoning: all is written at http://switchtoshapefile.org
Jachym
rouault
October 18, 2017, 12:36pm
2
On mercredi 18 octobre 2017 12:28:36 CEST Jachym Cepicky wrote:
--- vector/v.out.ogr/args.c (revision 71566)
@@ -32,7 +32,7 @@
- options->format->answer = "ESRI_Shapefile";
+ options->format->answer = "DPKG";
options->format->description = _("Data format to write");
any objections?
I'm not a GRASS dev, but do I have a major objection... There's a typo in your
patch Should be GPKG
Joke aside, the SQLite dependency in GDAL builds is optional, so in theory you
could have a GDAL build without SQLite/GPKG support. But this is really
unlikely in practice as no sane packager would do that. Perhaps checking if
the GPKG driver is there would be safer, and if not fallback to good old
shapefile.
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
Hi Evan,
oh, thanks for the typo, fixed in my code
There is driver check in the code
https://svn.osgeo.org/grass/grass/trunk/vector/v.out.ogr/main.c
line 457
for (i = 0; i < OGRGetDriverCount(); i++) {
I could probably commit, but before I do, I would like to get confirmed by PSC, this is OK to GRASS community.
Jachym
P.S. I’ve prepared similar patch for QGIS for those, who are interested https://github.com/qgis/QGIS/pull/5385
st 18. 10. 2017 v 14:36 odesílatel Even Rouault <even.rouault@spatialys.com > napsal:
@@ -32,7 +32,7 @@
any objections?
I’m not a GRASS dev, but do I have a major objection… There’s a typo in your
shapefile.
Even
Thanks again
This is not a good day for pushing for such complex changes for me. It would be safer, not to get out of the bed today.
switchfromshapefile.org is the page
J
st 18. 10. 2017 v 15:27 odesílatel Vincent Bain <bain@toraval.fr > napsal:
Hi Jachym : devil is in the details, ah, ah !
Le mercredi 18 octobre 2017 à 12:28 +0000, Jachym Cepicky a
écrit :
You probably meant switchfromshapefile.org ?
Thanks for all; here in France students massively still use shapefiles,
and worse! dumb tiff+tfw rasters. As though they had lived 30 years
sooner and would refuse improvements…
Vincent
please create a valid ticket on Trac for this issue. Thanks. Ma
2017-10-18 14:28 GMT+02:00 Jachym Cepicky <jachym.cepicky@gmail.com>:
@@ -32,7 +32,7 @@
any objections?
Jachym
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Oct 18, 2017 4:25 PM, “Martin Landa” <landa.martin@gmail.com > wrote:
Yes please.
And only for trunk (future 7.4) since we cannot touch default settings in released versions.
https://trac.osgeo.org/grass/ticket/3428
J
st 18. 10. 2017 v 16:30 odesílatel Markus Neteler <neteler@osgeo.org > napsal:
Yes please.
