[GRASS-dev] probable v.db.connect -g parsing problem
I notice a probable problem parsing v.db.connect's -g output. An
extra term containing the layer-name (if present) is added to the
first data column. e.g. if layer 1 had the name "layer_name"
G> v.db.connect -g fields2 fs='|'
1/layer_name|fields2|cat|.../$MAPSET/dbf/|dbf
   instead of
1|fields2|cat|.../$MAPSET/dbf/|dbf
see v.db.connect/main.c "if (fi->name) { fprintf( ..."
probably the solution is not too bad, just take the .split("/")[0]
term when dealing with column 1 in the GUI code.
I am not an expert in these things so I ask: under what conditions
would a vector DB layer have a name? Is it seen in the wild or is
it just an unused nice idea someone had?
Hamish
This is not an issue for gis.m in 6.5. Layer output of v.db.connect
isn't used/parsed, as user's provided layer number is used.
I was not able to find any (easy to spot) way how to name a layer, but
IIRC there are some modules, that add a name to layer during it's
creation.
Maris.
2009/8/24, Hamish <hamish_b@yahoo.com>:
   instead of
Hamish
grass-dev mailing list
grass-dev@lists.osgeo.org
Hamish wrote:
AFAICT, it is an unused nice idea that Radim had. The vector dblink functions in field.c support layer number and name, but I can't find a module that allows to set the layer name for a given layer number, it seems you have to hand-edit the dbln file. Vector modules don't allow (yet?) to select a layer by name instead of number. It is in Radim's vector TODO and I would like to add that functionality to GRASS7.
Markus M
