[GRASS-dev] problem bundling GRASS 6.5 and 6.4 RB
William,
I just recompiled GRASS 7 and bundled it for distribution. It went fine.
But when I went to do the same for GRASS 6.5 and 6.4 RB I ran into an odd error.
Compilation went fine. No errors in either. But bundling bombed with the following error:
cp -Rf /Library/Python/2.7/site-packages/pyparsing.py /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/etc/python
sed -i ‘’ -e ‘s/^GRASS_WXBUNDLED=.*/GRASS_WXBUNDLED=1/’ /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/grass.sh
sed: /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/grass.sh: No such file or directory
Is there no longer a grass.sh for GRASS 6.x? If not, what do we use to start it?
The same line does not cause an error for GRASS 7.
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
Woops. I deleted too much when I killed the modbuild stuff a few weeks ago. Should be working now.
On Feb 7, 2014, at 6:19 PM, Michael Barton wrote:
William,
sed -i '' -e 's/^GRASS_WXBUNDLED=.*/GRASS_WXBUNDLED=1/' /Users/cmbarton/Dropbox/GRASS_dropbox/source/grass64_rb/macosx/dist/GRASS-6.4.app/Contents/MacOS/grass.sh
Michael
______________________________
C. Michael Barton
USA
voice:
www:
Thanks. I'll try it again on Monday.
Michael Barton
School of Human Evolution &Social Change
...Sent from my iPad
On Feb 7, 2014, at 5:39 PM, "William Kyngesburye" <woklist@kyngchaos.com> wrote:
William,
Michael
C. Michael Barton
USA
voice:
www:
Something else has come up.
I compiled GRASS 7 on one computer Friday. It DID bundle OK (but maybe better now?). But when I went to run it on a different computer with the same OS, Python, and wxPython, I hit the following error at startup.
Either of you know what this may be? I don't know if it is a bundling issue or something else.
GRASS 7.0.svn (nc_spm_08):~ > Traceback (most recent call last):
  File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py", line 39, in <module>
    from lmgr.frame import GMFrame
  File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py", line 68, in <module>
    from modules.extensions import InstallExtensionWindow, UninstallExtensionWindow
ImportError: cannot import name UninstallExtensionWindow
Michael
C. Michael Barton
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Feb 7, 2014, at 5:39 PM, William Kyngesburye <woklist@kyngchaos.com> wrote:
William,
Michael
C. Michael Barton
USA
voice:
www:
On Mon, Feb 10, 2014 at 1:24 PM, Michael Barton <Michael.Barton@asu.edu>wrote:
There was a recent change in GUI related to extensions but it's working for
me. Have you updated properly? There shouldn't be any
UninstallExtensionWindow now, it's renamed to ManageExtensionWindow.
Anna
  File
  File
Michael
C. Michael Barton
>> William,
odd error.
>> sed:
start it?
>> Michael
>> C. Michael Barton
>> USA
>> voice:
>> www:
I did my normal make distclean followed by svn up. I can delete it all and have it add it all back in if you think that will help.
One thing is that it works fine on the machine I compile on, but bombs on a different machine.
Michael
On Mon, Feb 10, 2014 at 1:24 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Either of you know what this may be? I don’t know if it is a bundling issue or something else.
There was a recent change in GUI related to extensions but it’s working for me. Have you updated properly? There shouldn’t be any UninstallExtensionWindow now, it’s renamed to ManageExtensionWindow.
Anna
File “/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py”, line 39, in
File “/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py”, line 68, in
Michael
C. Michael Barton
William,
Michael
C. Michael Barton
USA
voice:
www:
On Mon, Feb 10, 2014 at 4:08 PM, Michael Barton <Michael.Barton@asu.edu>wrote:
I double checked and there is no `UninstallExtensionWindow` in source code
now, except for documentation:
./gui/wxpython/wxpythonlib.dox
Your error is at line 68 in lmgr/frame.py, but there is no
`import...UninstallExtensionWindow` now:
http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/lmgr/frame.py?rev=58946#L68
So, try svn diff, svn status, check your lmgr/frame.py file, check your
packaging process... It seems that the older version of the file is
packaged or perhaps imported from different GRASS on that other machine.
Hope this helps,
Vaclav
Michael
C. Michael Barton
USA
On Feb 10, 2014, at 11:51 AM, Anna Petrášová <kratochanna@gmail.com>
for me. Have you updated properly? There shouldn't be any
Anna
  File
  File
Michael
C. Michael Barton
>> William,
fine.
odd error.
>> sed:
start it?
>> Michael
>> C. Michael Barton
>> USA
>> voice:
>> www:
grass-dev mailing list
grass-dev@lists.osgeo.org
I’m starting from a clean update of GRASS 7 source from the SVN. I’ll let you know.
Michael
On Mon, Feb 10, 2014 at 4:08 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
I double checked and there is no UninstallExtensionWindow in source code now, except for documentation:
Your error is at line 68 in lmgr/frame.py, but there is no import...UninstallExtensionWindow now:
So, try svn diff, svn status, check your lmgr/frame.py file, check your packaging process… It seems that the older version of the file is packaged or perhaps imported from different GRASS on that other machine.
Hope this helps,
Vaclav
Michael
C. Michael Barton
USA
Anna
Michael
C. Michael Barton
William,
Michael
C. Michael Barton
USA
voice:
www:
I rebuilt and rebundled GRASS 7 yesterday evening. I started from a completely clean update (deleted all source files and did an svn up to restore then all with new ones).
There were no errors in compiling and building. BUT, I have a LOT or errors trying to run this from a different box than the one I compiled on. Any thoughts would be helpful. I’ll keep experimenting to see if this is a problem in compiling or bundling.
Michael
========== errors below ===============
Welcome to GRASS 7.0.svn
GRASS homepage: http://grass.osgeo.org
This version running through: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching GUI in the background, please wait…
ERROR: Incompatible library version for module. You need to rebuild GRASS
or untangle multiple installations.
File “/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/prompt.py”, line 11, in
gettext.install(‘grasslibs’, os.path.join(gisenv[‘GISDBASE’], ‘locale’), unicode = True)
KeyError: ‘GISDBASE’
GRASS 7.0.svn (nc_spm_08):~ > ERROR: Incompatible library version for module. You need to rebuild GRASS
File “/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py”, line 50, in
from lmgr.layertree import LayerTree, LMIcons
File “/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/layertree.py”, line 37, in
from mapdisp.frame import MapFrame
File “/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/mapdisp/frame.py”, line 40, in
from vdigit.toolbars import VDigitToolbar
File “/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/vdigit/toolbars.py”, line 23, in
from gui_core.dialogs import CreateNewVector, VectorDialog
ImportError: cannot import name VectorDialog
Hope this helps,
Vaclav
Michael
C. Michael Barton
USA
Anna
Michael
C. Michael Barton
William,
Michael
C. Michael Barton
USA
voice:
www:
I just realized that I did not list the entire error message. More clues at the end of it. I DO have GISDBASE set–and reset it just to be sure. Has here been a change to the configuration files and/or the way/place they are stored?
Michael
======= error message again =========
Hope this helps,
Vaclav
Michael
C. Michael Barton
USA
Anna
Michael
C. Michael Barton
William,
Michael
C. Michael Barton
USA
voice:
www:
On Tue, Feb 11, 2014 at 12:27 PM, Michael Barton <Michael.Barton@asu.edu>wrote:
It really seems that you have two GRASS version mixed at the other
computer. I'm not sure how Mac app works. I would say that libraries and/or
python packages from some old version are on PATH (or similar variable) and
are used by the newly compiled and installed GRASS.
Vaclav,
If you are correct, this is incorrect behavior.
It should not matter how many different installations of GRASS you have on a computer. Each one runs in its own environment. On the Mac especially, all the files for a version are contained in a *.app. GRASS should not be looking somewhere else for them.
But it is not yet clear to me what it is looking for that it finds multiple versions of.
Michael
On Tue, Feb 11, 2014 at 12:27 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
It really seems that you have two GRASS version mixed at the other computer. I’m not sure how Mac app works. I would say that libraries and/or python packages from some old version are on PATH (or similar variable) and are used by the newly compiled and installed GRASS.
On Tue, Feb 11, 2014 at 1:27 PM, Michael Barton <Michael.Barton@asu.edu>wrote:
Vaclav,
I don't know what are the possibilities to test what's happening. Perhaps,
check the environmental variables outside the GRASS session and inside
GRASS: PATH, DYLD_LIBRARY_PATH, DYLD_FALLBACK_LIBRARY_PATH, PYTHONHOME,
PYTHONPATH, GISBASE, GRASS_PYTHON and whatever is important for Mac, Python
or GRASS.
Vaclav
Michael
C. Michael Barton
Are you really running it from the source thru Dropbox on the other Mac? When running from source, the bundling hasn't happened yet, and maybe the other Mac is trying to use a different wxpython. To get GRASS binaries transferred to another Mac you need to make the bindist installer and install from that on the other Mac.
On Feb 11, 2014, at 11:27 AM, Michael Barton wrote:
I just realized that I did not list the entire error message. More clues at the end of it. I DO have GISDBASE set--and reset it just to be sure. Has here been a change to the configuration files and/or the way/place they are stored?
Michael
Launching <wxpython> GUI in the background, please wait...
  File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/prompt.py", line 11, in <module>
    gettext.install('grasslibs', os.path.join(gisenv['GISDBASE'], 'locale'), unicode = True)
KeyError: 'GISDBASE'
  File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/frame.py", line 50, in <module>
  File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/lmgr/layertree.py", line 37, in <module>
  File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/mapdisp/frame.py", line 40, in <module>
  File "/Users/cmbarton/Dropbox/GRASS_dropbox/source/grass7_dev/macosx/dist/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/vdigit/toolbars.py", line 23, in <module>
C. Michael Barton
voice:
There were no errors in compiling and building. BUT, I have a LOT or errors trying to run this from a different box than the one I compiled on. Any thoughts would be helpful. I'll keep experimenting to see if this is a problem in compiling or bundling.
Michael
C. Michael Barton
voice:
Michael
C. Michael Barton
USA
voice:
www:
I double checked and there is no `UninstallExtensionWindow` in source code now, except for documentation:
Your error is at line 68 in lmgr/frame.py, but there is no `import...UninstallExtensionWindow` now:
So, try svn diff, svn status, check your lmgr/frame.py file, check your packaging process... It seems that the older version of the file is packaged or perhaps imported from different GRASS on that other machine.
Hope this helps,
Vaclav
Michael
C. Michael Barton
USA
voice:
www:
There was a recent change in GUI related to extensions but it's working for me. Have you updated properly? There shouldn't be any UninstallExtensionWindow now, it's renamed to ManageExtensionWindow.
Anna
Michael
C. Michael Barton
>> William,
>> Michael
>> C. Michael Barton
>> USA
>> voice:
>> www:
No. I'm running the *.app that is created when I run bindist. But I'm running the app without copying it into my GRASS folder. It is in dropbox, but that is on my machine of course, just in the dropbox folder.
Michael
C. Michael Barton
On Feb 11, 2014, at 1:00 PM, William Kyngesburye <woklist@kyngchaos.com> wrote:
Michael
C. Michael Barton
voice:
Michael
C. Michael Barton
voice:
Michael
C. Michael Barton
USA
voice:
www:
frame.py in grass/trunk/gui/wxpython/lmgr – GRASS GIS
Hope this helps,
Vaclav
Michael
C. Michael Barton
USA
voice:
www:
Anna
Michael
C. Michael Barton
William,
Michael
C. Michael Barton
USA
voice:
www:
grass-dev Info Page
grass-dev Info Page
