[GRASS-dev] problem compiling grass 7 on ubuntu 8.04 (ctypes)
Hi developers,
I tried to compile grass 7 on Ubuntu 8.04 64bit. I have an error in:
/usr/local/grass_trunk/lib/python
So I change into the directory and run make:
/usr/local/grass_trunk/lib/python# make
make -C ctypes
make[1]: Entering directory /usr/local/grass_trunk/lib/python/ctypes' make /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib make[2]: Entering directory /usr/local/grass_trunk/lib/python/ctypes’
make[2]: /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib' is up to date. make[2]: Leaving directory /usr/local/grass_trunk/lib/python/ctypes’
make date.py grass.py raster.py gmath.py proj.py imagery.py vector.py display.py stats.py dbmi.py g3d.py arraystats.py cluster.py trans.py vedit.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/date.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/grass.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/raster.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/gmath.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/proj.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/imagery.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/vector.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/display.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/stats.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/dbmi.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/g3d.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/arraystats.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/cluster.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/trans.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/vedit.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/init.py /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/date.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/grass.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/raster.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/gmath.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/proj.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/imagery.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/vector.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/display.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/stats.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/dbmi.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/g3d.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/arraystats.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/cluster.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/trans.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/vedit.pyc /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/lib/init.pyc
make[2]: Entering directory /usr/local/grass_trunk/lib/python/ctypes' ctypesgen.py -I/usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/include -I/usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/include -L/usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/lib -L/usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/lib -lgrass_datetime /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/datetime.h /usr/local/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/P_datetime.h -o date.py make[2]: ctypesgen.py: Command not found make[2]: *** [date.py] Error 127 make[2]: Leaving directory /usr/local/grass_trunk/lib/python/ctypes’
make[1]: *** [default] Error 2
make[1]: Leaving directory `/usr/local/grass_trunk/lib/python/ctypes’
make: *** [default] Error 2
The ctypes is installed by synaptic. I also tried to run make in the directory /usr/local/grass_trunk/lib/python/ctypes (there is the makefile).
The error is:
make[1]: ctypesgen.py: Command not found
make[1]: *** [date.py] Error 127
Any idea? What’s the problem?
In the same machine I have grass 6.5 svn as well, and it works fine.
Thank you in advance
Margherita Di Leo
2010/5/17 Margherita Di Leo <diregola@gmail.com>:
Any idea? What's the problem?
http://lists.osgeo.org/pipermail/grass-dev/2010-May/050496.html
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
