[GRASS-dev] problem compiling grass7
I have problem compiling grass7 (probably related to the recent
changes in Make.*)
cd lib/pngdriver
if [ "pngdriver" != "" -a -f "pngdriver".html ] ; then make html ; fi
make[1]: Entering directory `/usr/local/src/grass_trunk/lib/pngdriver'
VERSION_NUMBER=7.0.svn
/usr/local/src/grass_trunk/tools/g.html2man/g.html2man.py
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/pngdriver.html
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/man/man1/pngdriver.1
make[1]: *** [/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/man/man1/pngdriver.1]
Error 1
make[1]: Leaving directory `/usr/local/src/grass_trunk/lib/pngdriver'
make: *** [lib] Error 2
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
changes in Make.*)
cd lib/pngdriver
Error 1
Right. This usually indicates that the HTML file isn't valid.
g.html2man.py exits with a non-zero status if it can't parse the HTML
file (although it doesn't print an error message).
Until recently, manual pages were generated by man/Makefile (the only
file in the man directory), while they are now generated alongside the
HTML (r33830 onwards).
An error in generating the manpage will be reported as an error in the
module (the top-level Makefile doesn't use Dir.make, so any errors in
its immediate children aren't reported in error.log).
I'm not sure why it's failing in this particular case. I don't get any
errors building that that file (or any other HTML file),
pngdriver.html hasn't changed in over a month, and I checked for any
broken HTML files within the last few days. Do you have any local
modifications?
2008/10/13 Glynn Clements <glynn@gclements.plus.com>:
modifications?
no, to be sure I have downloaded fresh code from SVN. Now I am getting
    self.fmt(spec, content)
  File "/home/martin/smetiste/grass_trunk/tools/g.html2man/g.html2man.py",
line 229, in fmt
    (pre,sep,post) = format.partition("@")
AttributeError: 'str' object has no attribute 'partition'
I am using python 2.4. Are we going to require python >= 2.5?
Martin
> modifications?
line 229, in fmt
Ah; the documentation says "New in version 2.5".
I've changed it to use split() instead. I don't know if there are any
other 2.5-isms in there.
