[GRASS-dev] Problem deleting raster created from point file using v.to.rast
Dear all,
I am using the command like-
v.to.rast --overwrite input=Temp_Aug_86@PERMANENT type=point output=Rast_Temp_Aug_86 column=Rain14
Rast_Temp_Aug_86@PERMANENT is created successfully.
But when I want to delete this raster using command like-
g.remove rast=Rast_Temp_Aug_86@PERMANENT
Then I get an error like below-
Removing raster Rast_Temp_Aug_86@PERMANENT
fcell: couldn’t be removed
I am also trying this by running " g.remove -f rast=Rast_Temp_Aug_86@PERMANENT " but same problem arises.
Please give me some solution to recover this problem.
Thanks & Regards,
Swapan
Does this error comes in deleting other maps. Could you try g.copy rast=old,new
and delete the newly created raster map.
Btw, Please tell your grass version and platform
On Sun, Mar 10, 2013 at 1:41 PM, SWAPAN GHOSH <swap.ghsh@gmail.com> wrote:
Dear all,
Thanks & Regards,
Swapan
grass-dev mailing list
grass-dev@lists.osgeo.org
Rashad
No, I am just creating new raster from point vector map…
here Temp_Aug_86 is point vector
but the problem is solve when we use command like-
v.to.rast --overwrite input=Temp_Aug_86@PERMANENT type=point output=Rast_Temp_Aug_86 column=Rain14 labelcolumn=cat
Regards
Swapan
Dear all,
Thanks & Regards,
Swapan
Rashad
I understand that from the command v.to.rast. what I asked is do you have problem deleting raster map “created” from v.to.rast or other raster maps. If you have problem deleting any raster map(create a duplicate and dont try with your actual data) then it this is an issue with g.remove.
I want to make sure that first
Also you didnt said about your grass version and platform yet.
I tried v.to.rast on spearfish dataset and here is the output
I copied archsites vector data as a backup.
g.copy vect=archsites,arch2
v.to.rast input=arch2@PERMANENT output=temp use=cat
Reading features…
100%
Writing raster map…
100%
Converted points/lines: 25 of 25
v.to.rast complete.
GRASS 7.0.svn (spearfish60):~ >
g.remove temp@PERMANENT
Removing raster temp@PERMANENT
Btw, I am using GRASS7.0 (SVN 55285) on Ubuntu 12.04
Regards
Swapan
On Sun, Mar 10, 2013 at 2:51 PM, Rashad M <mohammedrashadkm@gmail.com> wrote:
Rashad
Dear all,
Thanks & Regards,
Swapan
Rashad
no error will not occur for deleting other raster.
I use here grass6.5
regards,
swapan
Regards
Swapan
Rashad
Dear all,
Thanks & Regards,
Swapan
Rashad
