[GRASS-dev] problem initializing temporal gis
Hi everybody,
if I run python inside a GRASS session and after try to connect to the
database I obtain an error
import grass.temporal as tgis
dbif = tgis.SQLDatabaseInterfaceConnection()
  File "<stdin>", line 1, in <module>
  File "/home/lucadelu/compilati/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/core.py",
line 786, in __init__
    self.msgr.debug(1, "SQLDatabaseInterfaceConnection constructor")
AttributeError: 'NoneType' object has no attribute 'debug'
If I run the same code in a script I didn't obtain any error, some
advice to solve the problem?
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Hi Luca,
please call
tgis.init()
before any temporal operation is performed.
Best regards
Soeren
2014-06-24 10:51 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi everybody,
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
On 24 June 2014 13:05, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Luca,
please call
tgis.init()
thanks it fix the problem.
Is any information about the unit of values of temporal dataset (as
millimeter for precipitation or Celsius for temperature) ?
Best regards
Soeren
ciao
Luca
www.lucadelu.org
Hi Luca,
there is no dedicated field for unit specification. You can use the
description, or maybe better, the semantic field in the base
information object:
tgis.init()
stds = tgis.SpaceTimeRasterDataset("a@PERMANENT")
stds.base.set_semantic_type("unit:degree celsius")
stds.base.get_semantic_type()
'unit:degree celsius'
Best regards
Soeren
2014-06-24 16:32 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi Luca,
please call
tgis.init()
Best regards
Soeren
ciao
Luca
www.lucadelu.org
On 24 June 2014 17:10, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Luca,
Hi Soeren,
information object:
tgis.init()
ok thanks,
do you think could be possible to add a field for unit in future?
Best regards
Soeren
ciao
Luca
www.lucadelu.org
Hi Luca,
2014-06-27 15:08 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi Luca,
Hi Soeren,
information object:
tgis.init()
ok thanks,
Yes, it is possible to add any amount of fields in the future. Older
databases must then be updated to support the new fields, otherwise
the updated framework will not work with them.
However, a specific unit field that can be set by the user will
conflict with the unit field of raster and voxel maps. IMHO the unit
of a space time raster dataset should be derived from the units of the
registered raster maps. Well i did not implemented this, since from my
experience are units used very seldom for maps. So the correct
implementation would add a units fields to raster and 3d raster map
tables and to STRDS and STR3DS tables. The STDS SQL code must be
updated to aggregate the unit information. But what to do if map layer
have different units? Or if only a subset of the registered maps have
units?
So maybe the semantic type option is sufficient right now?
Best regards
Soeren
Best regards
Soeren
ciao
Luca
www.lucadelu.org
On 28 June 2014 12:32, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Luca,
Hi Soeren,
ok, so maybe it is better to collect idea and change only few times,
do you think I should open a ticket?
units?
In r.support there is units field, could we use this?
Can you do some example of map layer with different units?
But it accept only min, max, sum, mean value?
Best regards
Soeren
ciao
Luca
www.lucadelu.org
