I'm having a wee problem trying to compile r.modis on the trunk
version of GRASS. It does not seem to compile the pymodis library if
I'm getting that right:
GRASS 7.0.svn (eda-rsr):~ > g.extension ext=r.modis
Fetching <r.modis> from GRASS-Addons SVN (be patient)...
WARNING: gnome-keyring:: couldn't connect to:
/tmp/keyring-CTEtVP/pkcs11: No such file or directory
Compiling...
/bin/sh: 1: cannot create
/usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.download_to_translate.c:
Directory nonexistent
sed: couldn't flush stdout: Broken pipe
make[1]: [/usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.download_to_translate.c]
Error 2 (ignored)
/usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.import_to_translate.c:
make[1]: [/usr/local/grass-7.0.svn/locale/scriptstrings/r.modis.import_to_translate.c]
Error 2 (ignored)
Installing...
Updating metadata file...
Installation of <r.modis> successfully finished
GRASS 7.0.svn (eda-rsr):~ > r.modis.import
ERROR: modis library not found
Is that a bug?
Pierre
Scientist
Landcare Research, New Zealand
2013/10/8 Pierre Roudier <pierre.roudier@gmail.com>:
Is that a bug?
seems like that. Please report it. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Tue, Oct 8, 2013 at 4:46 AM, Pierre Roudier <pierre.roudier@gmail.com> wrote:
On Fedora 19 no problem:
GRASS 7.0.svn (nc_basic_spm_grass7):~ > g.extension r.modis
Compiling...
Installing...
Compiling...
Does at least /usr/local/grass-7.0.svn/locale/ exist?
On Tue, Oct 8, 2013 at 9:45 AM, Margherita Di Leo
So this one is missing?
/space/gis/grass_trunk/grass-7.0.svn/locale/scriptstrings/
(that should be easy to fix in g.extension)
Compiling...
Installing...
Forgot to mention that I'm running Ubuntu 12.04.2.
It does not - the correct path would be
/usr/local/src/grass7_trunk/locale/scriptstrings.
I am opening a bug in the trac,
Pierre
Scientist
