[GRASS-dev] problem regarding the display of map
hi,
i convert the raster map to vector map and the name of new vect map is map_tf_v
but when i use the display command i am getting following error
g.region vect=map_tf_v
ERROR: Cannot open old vector map_tf_v@PERMANENT on level 2
d.vect map=tgr_shp
The bounding box of the map is outside the current region, nothing drawn.
how can i display the map…???
thanks & regards
Arun K Verma
---------- Forwarded message ----------
Date: Feb 25, 2008 5:34 PM
Subject: problem regarding the display of map
To: grass-user@lists.osgeo.org, grass-dev@lists.osgeo.org
hi,
d.vect map=tgr_shp
thanks & regards
Arun K Verma
