I can't seem to remove mapsets in g.mapsets using the new removemapset parameter. Ex:
$ g.mapsets -p
ED_Legacy_Data PERMANENT 2007006
$ g.mapsets rem=2007006
$ g.mapsets -p
g.list is still fetching raster map names from the removed mapset as well:
$ g.list rast
raster files available in mapset <ED_Legacy_Data>:
<snip>
raster files available in mapset <PERMANENT>:
<snip>
raster files available in mapset <2007006>:
(all rasters follow)
~ Eric.
should be fixed now
http://trac.osgeo.org/grass/changeset/30939
Martin
2008/4/11, Patton, Eric <epatton@nrcan.gc.ca>:
$ g.mapsets -p
$ g.mapsets -p
$ g.list rast
<snip>
<snip>
~ Eric.
grass-user mailing list
grass-user@lists.osgeo.org
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
should be fixed now
Martin
Hi, yes I just tested it, works great. Thanks,
~ Eric.
