[GRASS-dev] Problem starting GRASS GUI - ntpath splitdrive
I’m trying to start GRASS GUI, but I always get this error message:
Cleaning up temporary files…
Starting GRASS GIS…
ERROR: Invalid return code from GUI startup script.
Please advise GRASS developers of this error.
Exiting…
Press any key to continue . . .
I tried GRASS 7.4.2 and 7.4.1 from OSGeo4W 64bits, and the standalone versions (32 and 64 bits). I also tried the 7.2.2, but without success.
C:\Windows\System32>grass74
File “C:\OSGEO4~1\apps\grass\grass-7.4.2\etc\grass74.py”, line 2025, in
main()
File “C:\OSGEO4~1\apps\grass\grass-7.4.2\etc\grass74.py”, line 1874, in main
ensure_home()
File “C:\OSGEO4~1\apps\grass\grass-7.4.2\etc\grass74.py”, line 720, in ensure_home
os.getenv(‘HOMEPATH’))
File “C:\OSGEO4~1\apps\Python27\lib\ntpath.py”, line 65, in join
result_drive, result_path = splitdrive(path)
File “C:\OSGEO4~1\apps\Python27\lib\ntpath.py”, line 115, in splitdrive
if len(p) > 1:
TypeError: object of type ‘NoneType’ has no len()
File “C:\Program Files (x86)\GRASS GIS 7.4.2\etc\grass74.py”, line 2025, in
main()
File “C:\Program Files (x86)\GRASS GIS 7.4.2\etc\grass74.py”, line 1874, in main
ensure_home()
File “C:\Program Files (x86)\GRASS GIS 7.4.2\etc\grass74.py”, line 720, in ensure_home
File “C:\Program Files (x86)\GRASS GIS 7.4.2\Python27\lib\ntpath.py”, line 65, in join
File “C:\Program Files (x86)\GRASS GIS 7.4.2\Python27\lib\ntpath.py”, line 115, in splitdrive
if len(p) > 1:
File “C:\Program Files\GRASS GIS 7.2.2\etc\grass72.py”, line 1984, in
main()
File “C:\Program Files\GRASS GIS 7.2.2\etc\grass72.py”, line 1833, in main
ensure_home()
File “C:\Program Files\GRASS GIS 7.2.2\etc\grass72.py”, line 716, in ensure_home
File “C:\Program Files\GRASS GIS 7.2.2\Python27\lib\ntpath.py”, line 73, in join
elif isabs(b):
File “C:\Program Files\GRASS GIS 7.2.2\Python27\lib\ntpath.py”, line 57, in isabs
s = splitdrive(s)[1]
File “C:\Program Files\GRASS GIS 7.2.2\Python27\lib\ntpath.py”, line 125, in splitdrive
if p[1:2] == ‘:’:
TypeError: ‘NoneType’ object has no attribute ‘getitem
Running GRASS algorithms from QGIS Processing, they work like expected, so the problem must be only on the GUI (WXPython?).
I’m using Windows 10.
Any tip for overcoming this problem?
Thank you very much!
Best regards,
Pedro Venâncio
po 5. 11. 2018 v 17:36 odesílatel Pedro Venâncio
<pedrongvenancio@gmail.com> napsal:
    os.getenv('HOMEPATH'))
  File "C:\OSGEO4~1\apps\Python27\lib\ntpath.py", line 65, in join
  File "C:\OSGEO4~1\apps\Python27\lib\ntpath.py", line 115, in splitdrive
    if len(p) > 1:
TypeError: object of type 'NoneType' has no len()
it seems that HOMEPATH environmental variable is not defined for your account.
I'm using Windows 10.
Based on [1] HOMEPATH should be defined on Windows 10 too.
Haven't you unset HOMEPATH for your account by chance? Try to set
HOMEPATH pointing to your home directory.
Martin
[1] https://www.tenforums.com/tutorials/3234-environment-variables-windows-10-a.html
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Hi Martin,
I did not have this environment variable set, but I set it and it still does not work.
Anyway, I don’t remember the last time I used GRASS GUI on this machine, but it was about 2 weeks ago.
Then this problem must have resulted from a recent change / update.
Thanks Martin.
Best regards,
Pedro
Martin Landa <landa.martin@gmail.com> escreveu no dia segunda, 5/11/2018 à(s) 16:40:
if len(p) > 1:
Haven’t you unset HOMEPATH for your account by chance? Try to set
Martin
Martin Landa
It seems a local problem here, because I’ve tested in another machine and everything works ok.
The strange thing is that both systems are similar, and it works in one, and not in another.
Now I only get this message:
C:>grass74
Starting GRASS GIS…
Exiting…
Running GRASS from the command line, works perfectly:
C:>grass74 -text
Starting GRASS GIS…
ATENÇÃO: Concurrent mapset locking is not supported on Windows
/ / __ / | / / / / __/ / /
/ / __/ /
/ / /| | _
\ / / __ / / _
/ / , / ___ |
_
// _///_/
Welcome to GRASS GIS 7.4.2
GRASS GIS homepage: http://grass.osgeo.org
This version running through: Command Shell (C:\WINDOWS\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
Start the GUI with: g.gui wxpython
When ready to quit enter: exit
Microsoft Windows [Version 10.0.17134.345]
(c) 2018 Microsoft Corporation. Todos os direitos reservados.
C:>
And also from QGIS (Processing and GRASS Plugin).
Any clue about what the problem could be?
Thank you very much.
Best regards,
Pedro
Pedro Venâncio <pedrongvenancio@gmail.com> escreveu no dia segunda, 5/11/2018 à(s) 17:28:
Hi Martin,
Thanks Martin.
Best regards,
Pedro
if len(p) > 1:
Martin
Martin Landa
C:\>grass74
Cleaning up temporary files...
Starting GRASS GIS...
Exiting...
what is the invalid return code?
is there another python installation on this windows system?
and not in another.
can you delete all the content in:
C:\Users\YourUserName\AppData\Roaming\GRASS7
and try to restart
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
On Tue, Nov 6, 2018 at 8:24 PM Helmut Kudrnovsky <hellik@web.de> wrote:
>C:\>grass74
>Exiting...
Our code could be more chatty :slight_smile:
https://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py#L1144
... at least write which code occurred?
C:\>grass74 -text
what is happening when you're in text mode and do
C:\>g.gui wxpython
best regards
Helmut
Hi Helmut,
Helmut Kudrnovsky <hellik@web.de> escreveu no dia terça, 6/11/2018 à(s) 19:24:
C:>grass74
Starting GRASS GIS…
Exiting…
The error falls here, like Markus said:
def gui_startup(grass_gui):
“”“Start GUI for startup (setting gisrc file)”“”
if grass_gui in (‘wxpython’, ‘gtext’):
ret = call([os.getenv(‘GRASS_PYTHON’), wxpath(“gis_set.py”)])
this if could be simplified to three branches (0, 5, rest)
if there is no need to handle unknown code separately
if ret == 0:
pass
elif ret in [1, 2]:
1 probably error coming from gis_set.py
2 probably file not found from python interpreter
formerly we were starting in text mode instead, now we just fail
which is more straightforward for everybody
fatal(_(“Error in GUI startup. See messages above (if any)”
" and if necessary, please"
" report this error to the GRASS developers.\n"
“On systems with package manager, make sure you have the right”
" GUI package, probably named grass-gui, installed.\n"
“To run GRASS GIS in text mode use the -text flag.\n”
“Use ‘–help’ for further options\n”
" {cmd_name} --help\n"
“See also: https://grass.osgeo.org/{cmd_name}/manuals/helptext.html”).format(
cmd_name=cmd_name))
elif ret == 5: # defined in gui/wxpython/gis_set.py
User wants to exit from GRASS
message((“Exit was requested in GUI.\nGRASS GIS will not start. Bye.”))
sys.exit(0)
else:
fatal(
(“Invalid return code from GUI startup script.\n”
“Please advise GRASS developers of this error.”))
Yes, I’ve Python 2.7 and Python 3.7, both instaled with OSGeo4W, one for QGIS 2.18 and another for QGIS 3.4. But I’ve the same on another machine.
and not in another.
and try to restart
I already tested this, but after delete it, it only create an empty GRASS7 folder.
what is happening when you’re in text mode and do
C:>g.gui wxpython
C:>g.gui wxpython
Launching GUI in the background, please wait…
C:>
but it does not launch the GUI. Looking at the windows task manager processes, the GRASS GUI process shows up, but closes right after a second or so.
Thank you very much for the help Helmut and Markus!
Best regards,
Pedro
I’ve done some more tests:
C:>grass74
Starting GRASS GIS…
/ / __/ /
/ / /| | _
\ / / __ / / _
/ / , / ___ |
_
// _///_/
C:>g.gui wxpython
C:>python
Python 2.7.14 (v2.7.14:84471935ed, Sep 16 2017, 20:25:58) [MSC v.1500 64 bit (AMD64)] on win32
Type “help”, “copyright”, “credits” or “license” for more information.
import wx
wx.version()
u’4.0.3 msw (phoenix) wxWidgets 3.0.5’
import sys
sys.executable
‘C:\OSGEO4~1\bin\python.exe’
print ‘\n’.join(sys.path)
C:\OSGEO4~1\apps\grass\grass-7.4.2\etc\python
C:\OSGeo4W64\apps\Python27
C:\OSGEO4~1\bin\python27.zip
C:\OSGEO4~1\apps\Python27\DLLs
C:\OSGEO4~1\apps\Python27\lib\plat-win
C:\OSGEO4~1\apps\Python27\lib\lib-tk
C:\OSGEO4~1\bin
C:\OSGEO4~1\apps\Python27\lib\site-packages
C:\OSGEO4~1\apps\Python27\lib\site-packages\jinja2-2.7.2-py2.7.egg
C:\OSGEO4~1\apps\Python27\lib\site-packages\markupsafe-0.23-py2.7-win-amd64.egg
C:\OSGEO4~1\apps\Python27\lib\site-packages\win32
C:\OSGEO4~1\apps\Python27\lib\site-packages\win32\lib
C:\OSGEO4~1\apps\Python27\lib\site-packages\Pythonwin
C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8-msw-unicode
quit()
C:>where python
C:\OSGeo4W64\bin\python.exe
Any suggestion about other tests I can run to check if something is missing?
I also tried to install GRASS 6.4 with OSGeo4W, but this time I get this error:
C:>grass64
File “C:/OSGEO4~1/apps/grass/grass-6.4.3/etc/wxpython/wxgui.py”, line 34, in
from lmgr.frame import GMFrame
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\wxpython\lmgr\frame.py”, line 46, in
from lmgr.layertree import LayerTree, LMIcons
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\wxpython\lmgr\layertree.py”, line 37, in
from mapdisp.frame import MapFrame
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\wxpython\mapdisp\frame.py”, line 38, in
from vdigit.toolbars import VDigitToolbar
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\wxpython\vdigit\toolbars.py”, line 23, in
from vdigit.main import VDigit
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\wxpython\vdigit\main.py”, line 18, in
from vdigit.wxdigit import IVDigit, GV_LINES
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\wxpython\vdigit\wxdigit.py”, line 33, in
from vdigit.wxdisplay import DisplayDriver
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\wxpython\vdigit\wxdisplay.py”, line 29, in
from grass.lib.vector import *
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\python\grass\lib\vector.py”, line 23, in
_libs[“grass_vect.6.4.3”] = load_library(“grass_vect.6.4.3”)
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\python\grass\lib\ctypes_loader.py”, line 55, in load_library
return self.load(path)
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\python\grass\lib\ctypes_loader.py”, line 221, in load
return WindowsLibrary(path)
File “C:\OSGEO4~1\apps\grass\grass-6.4.3\etc\python\grass\lib\ctypes_loader.py”, line 207, in init
self.cdll = ctypes.cdll.LoadLibrary(path)
File "C:\OSGEO4~1\apps\Python27\lib\ctypes_init
.py", line 444, in LoadLibrary
return self.dlltype(name)
.py", line 366, in init
self._handle = _dlopen(self._name, mode)
WindowsError: [Error 126] The specified module could not be found
C:>grass64 -text
Welcome to GRASS 6.4.3 (2013)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Windows Command Shell (cmd.exe)
GRASS 6.4.3 (pinhel)> g.gui
Launching ‘wxpython’ GUI in the background, please wait …
Any help will be very welcome!
Best regards,
Pedro
Pedro Venâncio <pedrongvenancio@gmail.com> escreveu no dia terça, 6/11/2018 à(s) 20:11:
Hi Helmut,
C:>grass74
Starting GRASS GIS…
Exiting…
if ret == 0:
pass
elif ret in [1, 2]:
cmd_name=cmd_name))
sys.exit(0)
else:
fatal(
and not in another.
and try to restart
C:>g.gui wxpython
C:>g.gui wxpython
C:>
Best regards,
Pedro
st 7. 11. 2018 v 12:02 odesílatel Pedro Venâncio
>>> import wx
>>> wx.version()
u'4.0.3 msw (phoenix) wxWidgets 3.0.5'
btw, have you installed wxPython on your own by pip? OSGeo4W still
comes with version 2.8.12 [1]
Ma
[1] https://download.osgeo.org/osgeo4w/x86_64/release/python/python-wx/
Martin Landa
Hi Martin,
Yes, I tried to update wxPython by pip, but it does not solved the problem.
Returning to 2.8.12 also does not help:
C:>pip uninstall wxpython
Uninstalling wxPython-4.0.3:
Would remove:
c:\osgeo4~1\apps\python27\lib\site-packages\wx*
c:\osgeo4~1\apps\python27\lib\site-packages\wxpython-4.0.3.dist-info*
c:\osgeo4~1\apps\python27\scripts\helpviewer.exe
c:\osgeo4~1\apps\python27\scripts\img2png.exe
c:\osgeo4~1\apps\python27\scripts\img2py.exe
c:\osgeo4~1\apps\python27\scripts\img2xpm.exe
c:\osgeo4~1\apps\python27\scripts\pycrust.exe
c:\osgeo4~1\apps\python27\scripts\pyshell.exe
c:\osgeo4~1\apps\python27\scripts\pyslices.exe
c:\osgeo4~1\apps\python27\scripts\pyslicesshell.exe
c:\osgeo4~1\apps\python27\scripts\pywxrc.exe
c:\osgeo4~1\apps\python27\scripts\wxdemo.exe
c:\osgeo4~1\apps\python27\scripts\wxdocs.exe
c:\osgeo4~1\apps\python27\scripts\wxget.exe
Proceed (y/n)? y
Successfully uninstalled wxPython-4.0.3
You are using pip version 18.0, however version 18.1 is available.
You should consider upgrading via the ‘python -m pip install --upgrade pip’ command.
C:>grass74
Starting GRASS GIS…
/ / __/ /
/ / /| | _
\ / / __ / / _
/ / , / ___ |
_
// _///_/
C:>g.gui wxpython
C:>python
import wx
wx.version()
‘2.8.12.1 (msw-unicode)’
import sys
C:\OSGEO4~1\bin
Thanks!
Best regards,
Pedro
Martin Landa <landa.martin@gmail.com> escreveu no dia quarta, 7/11/2018 à(s) 12:52:
import wx
wx.version()
Ma
Martin Landa
Hi Martin and Helmut,
About this issue, I finally find the problem.
I had changed the default code page in this machine long time ago (Regional Settings → Language for non-Unicode programs → and marked the beta option “Use Unicode UTF-8 for worldwide language support”).
And so, the active code page in windows console was 65001.
Unchecking that option, the defaut CHCP came back to 850, and the problem gone away!
Thank you very much for your help!
Best regards,
Pedro Venâncio
Pedro Venâncio <pedrongvenancio@gmail.com> escreveu no dia quarta, 7/11/2018 à(s) 14:10:
Hi Martin,
Would remove:
Proceed (y/n)? y
C:>grass74
Starting GRASS GIS…
/ / __/ /
/ / /| | _
\ / / __ / / _
/ / , / ___ |
_
// _///_/
C:>g.gui wxpython
C:>python
import wx
wx.version()
import sys
C:\OSGEO4~1\bin
Thanks!
Best regards,
Pedro
import wx
wx.version()
Ma
Martin Landa
