[GRASS-dev] Problem v.in.ascii (GRASS6.4.0RC4)
v.in.ascii -z input=fle_input output=name_output format=point fs= skip=0 x=1 y=2 z=3 cat=0 --overwrite --quiet
Output:
Segmentation fault
dbmi: Protocol error
Grass import correctly the points, but don’t create the associated table. anyone know the reason?
Roberto
Please consider the environment before printing this mail note!
I add some informations…
  • operating system: ubuntu 9.04
  • GRASS version: grass 6.4.0RC4
R
---------- Forwarded message ----------
From: roberto marzocchi <roberto.marzocchi@gmail.com>
Date: 2009/5/5
Subject: Problem v.in.ascii (GRASS6.4.0RC4)
To: grass-dev@lists.osgeo.org
Output:
Segmentation fault
Roberto
Output:
Segmentation fault
Grass import correctly the points, but don't create the associated table. anyone know the reason?
Is there any attribute data contained in the input file ? It would help if you sent us at least the first few lines of the data.
Also fs= seems weird. What is the field separator in the file ?
Moritz
in attached the input file
in grass6.3.0 the command run, the problem is only with the last grass version
R
2009/5/5 Moritz Lennert <mlennert@club.worldonline.be>
Output:
Segmentation fault
Moritz
(attachments)
profilo_30.txt (3.69 KB)
Have you tried quoting the fs, i.e.:
v.in.ascii -z input=fle_input output=name_output format=point fs=' ' skip=0 x=1 y=2 z=3 cat=0 --overwrite
Running it without quoting, I get:
ERROR: y column number > minimum last column number
        (incorrect field separator?)
With quoting it works (in the grass6 development branch).
How are you running this command ? On the command line ? In the GUI ?
Moritz
R
2009/5/5 Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>>
        Output:
        Segmentation fault
    Moritz
I have the same problem in the command line (using fs=' ') and using the GUI without quoting
maybe i have a problem with libraries....?
R
Moritz
R
        Output:
        Segmentation fault
    Moritz
Hi Roberto,
I can reproduce the problem:
GRASS 6.5.svn (spearfish60):/tmp > v.in.ascii -z input=profilo_30.txt
output=name_output format=point fs=" " skip=0 x=1 y=2 z=3 cat=0
Scanning input for column types...
Maximum input row length: 35
Maximum number of columns: 10
Minimum number of columns: 4
Importing points...
100%
Populating table...
No good.
GRASS 6.5.svn (spearfish60):/tmp > g.gisenv set=DEBUG=3
output=name_output format=point fs=" " skip=0 x=1 y=2 z=3 cat=0 --o
D2/3: Vect_open_new(): name = name_output
D2/3: load_table_head(): tab = 30,
/home/neteler/grassdata/spearfish60/neteler/dbf//name_output.dbf
D3/3: Doing SQL command <3> on DBF table... (see include/sqlp.h)
D2/3: load_table(): tab = 30
100%
Populating table...
D2/3: Commit transaction
D2/3: save_table 27
D2/3: save_table 28
D2/3: save_table 29
D2/3: save_table 30
D2/3: Write table to tempfile:
'/home/neteler/grassdata/spearfish60/neteler/.tmp/host550/17010.dbf'
D2/3: Write 108 rows
D3/3: Vect_build(): build = 4
Building topology for vector map <name_output>
The file /home/neteler/grassdata/spearfish60/neteler/.tmp/host550/17010.dbf
is only of
1 byte size, so corrupted.
Using the SQLite driver, I get a more useful error message:
DBMI-SQLite driver error:
Error in sqlite3_prepare():
table name_output has 11 columns but 10 values were supplied
D2/3: G__home home = /home/neteler
ERROR: Unable to insert new record: insert into name_output values ( 1,
       715514.14, 93561.67, 304.19, '53', null, null, null, null, null)
As we see: 5 empty columns are recognized.
This is because there are white spaces at the end of the first row,
maybe elsewhere, too.
So: GRASS is working but the error trapping in the DBF driver isn't
that good (the SQLite driver is better here).
Solution: polish the data file...
PS: the * in some rows will also cause problems.
On Tue, May 5, 2009 at 10:55 PM, roberto.marzocchi
GUI without quoting
R
version
Moritz
R
   v\.in\.ascii \-z input=fle\_input  output=name\_output format=point
   fs=  skip=0 x=1 y=2 z=3 cat=0 \-\-overwrite \-\-quiet
   Output:
   Segmentation fault
   Grass import correctly the points, but don&#39;t create the
   associated table\. anyone know the reason?
Moritz
grass-dev mailing list
Ok, without white space the command run correctly.
Grass 6.4 and 6.5 “don’t like” white space in a character string.
No problem with * character!
Many thanks
Roberto
2009/5/5 Markus Neteler <neteler@osgeo.org>
Hi Roberto,
Scanning input for column types…
Importing points…
100%
Populating table…
No good.
D3/3: Doing SQL command <3> on DBF table… (see include/sqlp.h)
100%
Populating table…
D2/3: save_table 27
D2/3: save_table 28
D2/3: save_table 29
D2/3: save_table 30
‘/home/neteler/grassdata/spearfish60/neteler/.tmp/host550/17010.dbf’
is only of
715514.14, 93561.67, 304.19, ‘53’, null, null, null, null, null)
So: GRASS is working but the error trapping in the DBF driver isn’t
Solution: polish the data file…
I have the same problem in the command line (using fs=’ ') and using the
GUI without quoting
maybe i have a problem with libraries…?
R
version
v.in.ascii -z input=fle_input output=name_output format=point fs=’ ’
Moritz
R
mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)>
Output:
Segmentation fault
Moritz
Roberto Marzocchi
SUPSI-Istituto scienze della terra -Institute of Earth Sciences
Via Trevano C.P. 72 6952 Canobbio Switzerland
Phone: +41 58 6666 212
Fax: +41 58 6666 209
E-mail: roberto.marzocchi@supsi.ch
Internet: www.ist.supsi.ch
On Wed, May 6, 2009 at 9:02 AM, roberto marzocchi
Grass 6.4 and 6.5 "don't like" white space in a character string.
No, it is slightly different: Of course you can have white space in
strings. But in your case, you have white space as separator at
the same moment - obviously creating a conflict.
sure - I just thought that you wanted to import the number column
as numbers not as chars.
