Yann3
April 5, 2009, 3:27pm
1
Hello list,
Could you please help,
I have updated i.modis.qc, and it compiles well.
However, the html file somehow makes an error on compilation of the module.
The compilation fails because of that one.
Is there a way to know where in the html file it stops?
Yann
Yann Chemin
Mobile: +33 (06) 10 11 39 26
Home: +33 (02) 35 27 08 20,
Address: Gite de Mortagne,
16 rue de la chenaie,
76110 Bec de Mortagne,
France
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
2009/4/5 Yann Chemin <yann.chemin@gmail.com>:
I guess your are referring to trunk. See SUBMITTING_DOCS for supported
tags. Can you send error log?
M.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Yann3
April 5, 2009, 3:54pm
3
Hello Martin,
yes, since I just copied a valid GRASS description html into this one,
I believe it is a different problem.
here is the error on the command line.
root@siduxbox:/home/yann/tmp/grass_yann/imagery/i.modis.qc# make
gcc -I/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/include -g -O2
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
-I/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/main.o -c main.c
gcc -L/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/lib
-Wl,--export-dynamic
-Wl,-rpath-link,/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/lib
-L/usr/lib/ -o
/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/bin/i.modis.qc
OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/mod09A1a.o
OBJ.i686-pc-linux-gnu/mod09A1c.o OBJ.i686-pc-linux-gnu/mod09A1d.o
OBJ.i686-pc-linux-gnu/mod09A1e.o OBJ.i686-pc-linux-gnu/mod09A1sa.o
OBJ.i686-pc-linux-gnu/mod09A1sb.o OBJ.i686-pc-linux-gnu/mod09A1sc.o
OBJ.i686-pc-linux-gnu/mod09A1sd.o OBJ.i686-pc-linux-gnu/mod09A1se.o
OBJ.i686-pc-linux-gnu/mod09A1sf.o OBJ.i686-pc-linux-gnu/mod09A1sg.o
OBJ.i686-pc-linux-gnu/mod09A1sh.o OBJ.i686-pc-linux-gnu/mod09A1si.o
OBJ.i686-pc-linux-gnu/mod09A1sj.o OBJ.i686-pc-linux-gnu/mod09A1sk.o
OBJ.i686-pc-linux-gnu/mod09Q1a.o OBJ.i686-pc-linux-gnu/mod09Q1b.o
OBJ.i686-pc-linux-gnu/mod09Q1c.o OBJ.i686-pc-linux-gnu/mod09Q1d.o
OBJ.i686-pc-linux-gnu/mod09Q1e.o OBJ.i686-pc-linux-gnu/mod09Q1f.o
OBJ.i686-pc-linux-gnu/mod11A2a.o OBJ.i686-pc-linux-gnu/mod11A2b.o
OBJ.i686-pc-linux-gnu/mod11A2c.o OBJ.i686-pc-linux-gnu/mod11A2d.o
-lgrass_gis -lgrass_datetime -lz -lm -lz
if [ "/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/bin/i.modis.qc"
!= "" ] ; then GISRC=/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/demolocation/.grassrc70
GISBASE=/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu
PATH="/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/bin:$PATH"
PYTHONPATH="/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/etc/python:$PYTHONPATH"
LD_LIBRARY_PATH="/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/bin:/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/lib:"
LC_ALL=C /home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/bin/i.modis.qc
--html-description < /dev/null | grep -v '</body>\|</html>' >
i.modis.qc.tmp.html ; fi
Segmentation fault
make: *** [i.modis.qc.tmp.html] Error 1
rm i.modis.qc.tmp.html
Thanks a lot,
Yann
2009/4/5 Martin Landa <landa.martin@gmail.com>:
M.
Yann Chemin
France
Yann3
April 5, 2009, 4:08pm
4
OK, found it, sorry for the trouble.
it was a duplicate line from a copy/paste that got itself in the wrong place
input1->answer = _("modland_qa_bits");
it was before
input1 = G_define_option();
Yann
Hello Martin,
-L/usr/lib/ -o
Segmentation fault
Thanks a lot,
Yann
M.
Yann Chemin
France
Yann Chemin
France
it was before
not really, fixed r36595 (G_parser() segfault).
M.
Yann3
April 5, 2009, 7:06pm
6
OK thanks Martin.
it was before
M.
Yann Chemin
France
