[GRASS-dev] Problem with font selection in gis.m on Windows
The recent talk of fonts on this list brought me to try out some stuff on Windows. I discovered there's a font selector control in gis.m (Config Menu-->Set default display font) but if I click the button to try and change it to anything other than Romans I get the following error:
couldn't execute "uname": no such file or directory
     while executing
"exec uname -s"
     (procedure "Gm::SelectFont" line 7)
     invoked from within
"Gm::SelectFont"
     ("uplevel" body line 1)
     invoked from within
"uplevel \#0 $cmd"
     (procedure "Button::_release" line 18)
     invoked from within
"Button::_release .dispfont.fontopt2.b"
     (command bound to event)
Obviously trying to use the "uname" command (not available on native Windows) is the bug, but looking closer at the code (line 537 onwards in gui/tcltk/gis.m/gm.tcl) it seems the relevant part is trying to put together directories to search for Freetype fonts in? Which
(a) shouldn't even be needed here as I have the stroke font radio button in the dialog selected and don't even have GRASS compiled with Freetype support and
(b) might possibly be being made redundant by Glynn's new script to populate $GISBASE/etc/freetypecap?
Not sure what's the best way to fix this, taking into account those points.
Paul
I lifted this from Init.sh, where it checks for things like Mingw and
Cygwin, so I thought it would work with windows. If it doesn't, I guess it's
pointless to have it in Init.sh too.
As the current font selection is done, I need to know if a Mac, Windows, or
other system is running to know where to look for fonts. If uname doesn't
work on Windows, I don't know how to find this out.
If there is no other solution, I'll try to implement an alternate kind of
dialog, using a listbox and the new and improved freetypecap file, like I've
done for the wxPython GUI.
Michael
     while executing
"exec uname -s"
     invoked from within
"Gm::SelectFont"
     invoked from within
"uplevel \#0 $cmd"
     invoked from within
support and
points.
Paul
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
uname will generally be available if Init.sh works, but Init.sh only runs in Msys on Windows - true native Windows GRASS doesn't require Msys for running (only compiling) and won't have Unix commands like uname available at run-time. We have an alternative Windows batch file, init.bat, that can be used to start native Windows GRASS and avoids the need to have a shell interpreter and run Init.sh.
Usually I did platform checking in Tcl by looking for environment variables that were platform-specific, e.g. something like:
if {[info exists env(OS)] && $env(OS) == "Windows_NT"}
but I see in the new d.rast.edit Glynn has used some kind of Tcl variable which looks like an even neater way of doing it:
if {$tcl_platform(platform) == "windows"}
But I agree it's best to wait to see how the font support settles down before we decide how best to fix this.
Michael
     while executing
"exec uname -s"
     invoked from within
"Gm::SelectFont"
     invoked from within
"uplevel \#0 $cmd"
     invoked from within
support and
points.
Paul
phone: 480-965-6213
fax: 480-965-7671
Thanks for the useful tips.
Michael
Michael
     while executing
"exec uname -s"
     invoked from within
"Gm::SelectFont"
     invoked from within
"uplevel \#0 $cmd"
     invoked from within
support and
points.
Paul
phone: 480-965-6213
fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
Glynn,
Paul Kelly sent me this great-sounding tip as a way to get system
information without invoking the Unix command uname, which is unavailable
under windows.
The only problem is that I get an error...
can't read "tcl_platform(platform)": no such variable
...whenever I try to invoke it in a TclTk script. Even odder, if I invoke it
from a wish command line, it is fine (though it report unix on my Mac
because I'm using x11).
Is there some secret trick to using this? It is not apparent in the TclTk
docs that I'm reading.
Michael
phone: 480-965-6213
fax: 480-965-7671
------ Forwarded Message
Date: Sun, 6 May 2007 05:05:46 +0100 (BST)
To: Michael Barton <michael.barton@asu.edu>
Cc: <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] Problem with font selection in gis.m on Windows
------ End of Forwarded Message
under windows.
Are you using it from within a procedure? If so, you need to use
"global tcl_platform", as with any other global variable.
I've fixed this in the CVS, so that setting the default font should work
with Windows now.
Michael
under windows.
phone: 480-965-6213
fax: 480-965-7671
with Windows now.
OK thanks I made a few more changes and now it is working quite well. Most notably that the
global env, tcl_platform
syntax didn't work (env(GISBASE) was an unknown variable) and I had to change it to:
global env
global tcl_platform
(which is what the Tcl documentation suggests anyway; ISTR coming across this before but it seemed to be OK then. Not too sure.)
The other noteworthy change was using the Native Tk file browser widget ::tk::dialog::file:: instead of the native Windows one that tk_getOpenFile uses. The native Windows one was very slow and clunky and most importantly didn't work for selecting fonts from the Windows fonts directory. Clicking on a file didn't put it into the selection box and double-clicking opened a Window displaying the font's capabilities. The native Tk widget admittedly has a distinct early-90s look to it but it is fast and (most importantly) works.
Paul
> with Windows now.
notably that the
change it to:
global env
global tcl_platform
You can specify multiple variables in a single "global" statement, but
there shouldn't be any commas. "global env, tcl_platform" will attempt
to import a variable named "env," (with a trailing comma).
Thanks Paul. I'll update my version.
Michael
with Windows now.
notably that the
change it to:
global env
global tcl_platform
Paul
phone: 480-965-6213
fax: 480-965-7671
Typo on my part. I'm surprised it work OK for me.
Michael
On 5/7/07 7:18 AM, "Glynn Clements" <glynn@gclements.plus.com> wrote:
with Windows now.
notably that the
change it to:
global env
global tcl_platform
phone: 480-965-6213
fax: 480-965-7671
So, without uname, is there another reliable way on the command line/in a shell script, not in Tcl?
I worked a way to get grass-xterm-wrapper to work with the OSX Terminal.app instead of X11 xterm, but I use uname to check the system so OSX defaults to Terminal.app. It'll still work without that bit, but GRASS_XTERM would need to be explicitly set - no big deal, I can move the default to the OSX startup or init.sh.
On May 6, 2007, at 3:31 PM, Michael Barton wrote:
Glynn,
under windows.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
AFAIU it's only on native Windows where uname is a problem. It's fine on
BSD/OSX. grass-xterm-wrapper is explicitly a #!/bin/sh script, so using
UNIXisms inside that is not a problem. Or another way, native Windows
can't use the grass-xterm-wrapper script anyway.
Hamish
