[GRASS-dev] problem with r.shaded.relief on win7 and vista
I had a problem generating shaded relief (nc dataset, raster: elevation) both on Windows 7 and on Windows Vista, but not on XP, using 6.4.2RC2. Resulting map is scratched with vertical lines. Region was set at 1 meter of resolution. Please could anyone using those platforms verify that? I’d like someone to confirm the defect before opening the bug. Thanks!
Best regards,
madi
Eng. Margherita Di Leo
Ph.D. Candidate
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata
Campus Macchia Romana
85100 - Potenza
Office: +39-0971205360
http://osgeo-org.1803224.n2.nabble.com/file/n7201493/rsr_res1m.png
tested here on winvista32-box (nc dataset, raster: elevation), g.region
res=1m
I can confirm this.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/problem-with-r-shaded-relief-on-win7-and-vista-tp7201314p7201493.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
res=1m
Yes but the elevation map does not have one meter resolution AFAIK?
You need to use e.g.
g.region align=elevmap
prior to r.shaded.relief to match the elevation map resolution.
res=1m
You need to use e.g. g.region align=elevmap prior to r.shaded.relief to
yes I know, but it seems to be a different behaviour between winxp and
winVista/win7
(see original mail from Margherita di Leo).
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/problem-with-r-shaded-relief-on-win7-and-vista-tp7201314p7201910.html
