[GRASS-dev] Problems 3D rendering with WxNviz (Ubuntu)
it wanted to try out the 3D capabilities of GRASS 7. However when I change to the 3d view (WxNviz) nothing is rendered, instead I get the message that I should try a different depth buffer number. This procedure is also mentioned in the wiki (http://grasswiki.osgeo.org/wiki/WxNviz).
However, I tried now all possible numbers (0,16,24,32) saved the preferences and restarted the gui with the new settings but the problem persists (BTW, the possible number 0 is mentioned in the wiki but not in the preferences GUI).
I am not sure what is causing the problem in my case. Here I just need to mention that I am working on a slightly special set up. GRASS is running on a virtual Ubuntu machine (via VMWare) which is installed on a central multi core machine (Intel® Xeon(R) CPU X5675 @ 3.07GHz × 8, Ubuntu 12.04, 32 bit). I connect to the virtual machine via a remote desktop connection (RDP connection) from a so called thin-client.
My GRASS setup as follows:
version=7.0.svn
date=2014
revision=59321M
build_date=2014-03-25
build_platform=i686-pc-linux-gnu
libgis_revision=59317
libgis_date="2014-03-24 20:38:32 +0100 (Mon, 24 Mar 2014) "
proj4=4.8.0
gdal=1.10.0
geos=3.3.8
sqlite=3.7.9
Does anyone have a suggestion how to deal with that problem or how to find out where the exact problem (remote connection, Ubuntu, GRASS) is located?
Johannes
On Tue, Mar 25, 2014 at 6:30 AM, Johannes Radinger <
johannesradinger@gmail.com> wrote:
version=7.0.svn
date=2014
revision=59321M
proj4=4.8.0
gdal=1.10.0
geos=3.3.8
sqlite=3.7.9
Could you post also wxPython version?
Thanks
Anna
Johannes
grass-dev mailing list
grass-dev@lists.osgeo.org
I just reinstalled wxPython and recompiled GRASS to be sure that I am working with the newest versions.
The problem still persists. Here how I installed wxPython:
  sudo apt-get install python-wxgtk2.8 python-wxtools wx2.8-doc wx2.8-examples wx2.8-headers wx2.8-i18n
and then I also followed another procedure explained here: http://stackoverflow.com/questions/14007557/installing-wxpython-on-ubuntu-12-04
  1. First make sure that you have Python installed
  2. Install wxGTK 2.8 with the command, ‘sudo apt-get install python-wxgtk2.8’
  3. Run the command, ‘apt-get source -d wxwidgets2.8’
  4. Now run, ‘dpkg-source -x wxwidgets2.8_2.8.12.1-6ubuntu2.dsc’
  5. cd wxwidgets2.8-2.8.12.1
  6. cd wxPython
  7. Now run the command, ‘sudo python setup.py install’
  8. wxPython and wxWidgets are now successfully installed!
Now it seems that two versions are installed
import wxversion
wxversion.getInstalled()
[‘2.8-gtk2-unicode’, ‘2.8-gtk2-unicode’]
Does that help?
Is there a way the GRASS itself reports the versions of e.g. wxpython? Maybe via the g.version command?!
/Johannes
On Wed, Mar 26, 2014 at 5:11 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
On Tue, Mar 25, 2014 at 6:30 AM, Johannes Radinger <johannesradinger@gmail.com> wrote:
version=7.0.svn
date=2014
revision=59321M
proj4=4.8.0
gdal=1.10.0
geos=3.3.8
sqlite=3.7.9
Thanks
Anna
Johannes
On Wed, Mar 26, 2014 at 5:27 AM, Johannes Radinger <
   2. Install wxGTK 2.8 with the command, 'sudo apt-get install
   python-wxgtk2.8'
   3. Run the command, 'apt-get source -d wxwidgets2.8'
   4. Now run, 'dpkg-source -x wxwidgets2.8_2.8.12.1-6ubuntu2.dsc'
   6. cd wxPython
   7. Now run the command, 'sudo python setup.py install'
>>> import wxversion
['2.8-gtk2-unicode', '2.8-gtk2-unicode']
Does that help?
When you go in menu Help ->About system you should be able to see it. Also,
when you go to Python Shell, you can type:
import wx
wx.version()
In wxPython >= 2.9, there is a method IsDisplaySupported which would help
to understand more about the problem [1]. The only thing which I know you
could try is to install wxPython 3. You can either compile it yourself or
update Ubuntu to the latest one and install the package. However I can't
guarantee it helps.
Anna
[1]
http://stackoverflow.com/questions/14715739/how-can-i-determine-the-max-allowable-wx-gl-depth-size-for-a-wx-glcanvas/
/Johannes
On Wed, Mar 26, 2014 at 5:11 AM, Anna Petrášová <kratochanna@gmail.com>wrote:
version=7.0.svn
date=2014
revision=59321M
proj4=4.8.0
gdal=1.10.0
geos=3.3.8
sqlite=3.7.9
located?
Thanks
Anna
Johannes
Hi Anna,
to report back. I know successfully built and installed wxPython3. Subsequently I rebuilt and installed GRASS7
based on the newest revision. Here my system and version output:
GRASS version: 7.0.svn
GRASS SVN Revision: 59491M
Build Date: 2014-03-28
Build Platform: i686-pc-linux-gnu
GDAL/OGR: 1.10.0
PROJ.4: 4.8.0
GEOS: 3.3.8
SQLite: 3.7.9
Python: 2.7.3
wxPython: 3.0.0.0
Platform: Linux-3.2.0-60-generic-pae-i686-with-Ubuntu-12.04-precise
GRASS 7.0.svn (2014)
libgis Revision: 59317
libgis Date: 2014-03-24 20:38:32 +0100 (Mon, 24 Mar 2014)
PROJ.4: 4.8.0
GDAL/OGR: 1.10.0
GEOS: 3.3.8
SQLite: 3.7.9
I again tried setting all 4 possible numbers for the depth buffer. But still, GRASS does not render any 3D rastermap. In contrast to before, now I don’t the message that I should try changing the buffer number.
Here some output from the Python Shell that may or may not be helpful:
import wx
import wxversion
wx.glcanvas.GLCanvas_IsDisplaySupported([0,16,24,32])
False
wx.glcanvas.GLCanvas_IsDisplaySupported([0])
False
wx.glcanvas.GLCanvas_IsDisplaySupported([16])
False
wx.glcanvas.GLCanvas_IsDisplaySupported([24])
False
wx.glcanvas.GLCanvas_IsDisplaySupported([32])
False
<function getInstalled at 0xb6f89bfc>
[‘3.0-gtk2’]
I get now a problem reported in the GUI’s command console which is printed when I start the 3D viewing mode:
Starting 3D view mode…
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/to
olbars.py”, line 230, in OnSelectTool
self.parent.AddNviz()
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/mapdisp/fr
ame.py”, line 362, in AddNviz
Map = self.Map, tree = self.tree, lmgr = self._layerManager)
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/nviz/mapwi
ndow.py”, line 118, in init
self.context = glcanvas.GLContext(self)
File “/usr/local/lib/python2.7/dist-
packages/wx-3.0-gtk2/wx/glcanvas.py”, line 67, in init
_glcanvas.GLContext_swiginit(self,_glcanvas.new_GLContext(*a
rgs, **kwargs))
wx._core
PyAssertionError
C++ assertion “vi” failed at /usr/local/src/wxPython-
src-3.0.0.0/src/unix/glx11.cpp(59) in wxGLContext(): invalid
visual for OpenGL
So maybe this can give some hints. Just let me know what I can do that you can help me solving the problem.
Best,
Johannes
On Wed, Mar 26, 2014 at 5:40 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
On Wed, Mar 26, 2014 at 5:27 AM, Johannes Radinger <johannesradinger@gmail.com> wrote:
  6. cd wxPython
import wxversion
Does that help?
When you go in menu Help ->About system you should be able to see it. Also, when you go to Python Shell, you can type:
import wx
wx.version()
In wxPython >= 2.9, there is a method IsDisplaySupported which would help to understand more about the problem [1]. The only thing which I know you could try is to install wxPython 3. You can either compile it yourself or update Ubuntu to the latest one and install the package. However I can’t guarantee it helps.
Anna
[1] http://stackoverflow.com/questions/14715739/how-can-i-determine-the-max-allowable-wx-gl-depth-size-for-a-wx-glcanvas/
/Johannes
version=7.0.svn
date=2014
revision=59321M
proj4=4.8.0
gdal=1.10.0
geos=3.3.8
sqlite=3.7.9
Thanks
Anna
Johannes
On Fri, Mar 28, 2014 at 7:46 AM, Johannes Radinger <johannesradinger@gmail.com> wrote:
Hi Anna,
GDAL/OGR: 1.10.0
PROJ.4: 4.8.0
GEOS: 3.3.8
SQLite: 3.7.9
Python: 2.7.3
wxPython: 3.0.0.0
PROJ.4: 4.8.0
GDAL/OGR: 1.10.0
GEOS: 3.3.8
SQLite: 3.7.9
import wx
import wxversion
False
False
False
False
False
[‘3.0-gtk2’]
You should try this:
import wx
from wx.glcanvas import WX_GL_DEPTH_SIZE
wx.glcanvas.GLCanvas_IsDisplaySupported([WX_GL_DEPTH_SIZE, 0, 0])
wx.glcanvas.GLCanvas_IsDisplaySupported([WX_GL_DEPTH_SIZE, 16, 0])
wx.glcanvas.GLCanvas_IsDisplaySupported([WX_GL_DEPTH_SIZE, 32, 0])
rgs, **kwargs))
wx._core
PyAssertionError
visual for OpenGL
I am wondering if it can’t be some deeper problem, could you try to run any other application which uses OpenGL? For example MeshLab is using it I think, or any other you use.
Anna
Best,
Johannes
  6. cd wxPython
import wxversion
Does that help?
import wx
wx.version()
Anna
/Johannes
version=7.0.svn
date=2014
revision=59321M
proj4=4.8.0
gdal=1.10.0
geos=3.3.8
sqlite=3.7.9
Thanks
Anna
Johannes
