[GRASS-dev] problems compiling GRASS 6.3 cvs on Mac
William,
I just tried to update and compile GRASS 6.3 on my Mactel MacBook. (I did a make distclean first)
I had the usual d.m error, but also can’t compile r.out.tiff.
Here is the error:
cmb-MBP-2:~/grass_dev/grass6/raster/r.out.tiff cmbarton$ make
gcc -L/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.3/lib -o /Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.3/bin/r.out.tiff OBJ.i686-apple-darwin8.10.3/r.out.tiff.o -lgrass_gis -lgrass_datetime -lz -ltiff -lz
/usr/bin/ld: can’t locate file for: -ltiff
collect2: ld returned 1 exit status
make: *** [/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.3/bin/r.out.tiff] Error 1
I had no problem with configure. I’m downloading a new all frameworks to see if I’m missing anything new and then will compile again. (Any chance you could put a date on these in your site so it would be clear which, if any have been updated recently?)
Michael
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Hehe, I just had the same minutes ago... From the link command, I see that the libtiff dir is not included:
gcc -L/Users/Shared/src/GRASS/cvs/grass6/dist.i686-apple-darwin8.10.1/lib -arch ppc -arch i386 -arch ppc -arch i386 -L/usr/local/pgsql/lib -o /Users/Shared/src/GRASS/cvs/grass6/dist.i686-apple-darwin8.10.1/bin/r.out.tiff OBJ.i686-apple-darwin8.10.1/r.out.tiff.o -lgrass_gis -lgrass_datetime -lz -ltiff -lz
I think the recent makefile cleanup may have triggered a problem with the r.out.tiff makefile. It seems that EXTRA_CFLAGS is no longer added to link commands (which makes sense). But the r.out.tiff makefile doesn't add the libtiff path to LIBES:
LIBES = $(GISLIB) $(TIFFLIB)
It should probably be (indeed, this fixes it for me):
LIBES = $(GISLIB) $(TIFFLIBPATH) $(TIFFLIB)
(And TIFFLIBPATH should be removed from EXTRA_CFLAGS)
On Oct 20, 2007, at 7:00 PM, Michael Barton wrote:
William,
I had the usual d.m error, but also can't compile r.out.tiff.
Here is the error:
/usr/bin/ld: can't locate file for: -ltiff
I had no problem with configure. I'm downloading a new all frameworks to see if I'm missing anything new and then will compile again. (Any chance you could put a date on these in your site so it would be clear which, if any have been updated recently?)
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
Yup. Fixed it for me too.
Michael
William,
Here is the error:
- Marvin
phone: 480-965-6213
fax: 480-965-7671
Fixed in CVS.
Thanks Glynn.
Michael
Fixed in CVS.
phone: 480-965-6213
fax: 480-965-7671
Helena Mitasova wrote:
it is almost working now. It is only the nan value that is still causing
problems - you were right that the computation was correctly done for
most of the area but because of the nan value the color table was not
set correctly and the resulting map was plain white.
I have an area in the series that is set to zero (ocean level) so those
are the identical values where I am getting 0/0=nan. I can imagine other
situations where this can happen so it would be good to change the nan
result to null.
I've added the following change to CVS, which should catch NaNs:
--- lib/stats/c_reg.c~ 2007-10-23 13:33:32.000000000 +0100
+++ lib/stats/c_reg.c 2007-10-23 19:34:29.000000000 +0100
@@ -70,6 +70,10 @@
     G_set_d_null_value(result, 1);
     break;
+ /* Check for NaN */
+ if (*result != *result)
+ G_set_d_null_value(result, 1);
void c_reg_m(DCELL *result, DCELL *values, int n)
@@ -153,6 +157,10 @@
     break;
void w_reg_m(DCELL *result, DCELL (*values)[2], int n)
I still have no idea if the actual calculation is correct, or even
*which* coefficient it's calculating.
> result to null.
@@ -70,6 +70,10 @@
     break;
     break;
What I forgot to add (and the reason I CC'd to grass-dev), is that
G_is_[fd]_null_value() should probably check for any IEEE NaN, rather
than for a specific bit pattern.
I initially thought about adding such a check to the raster I/O code,
but that doesn't account for cases where nulls are tested for within
the module which generates them.
The main question is whether such a change should be made in 6.3 or
reserved for 7.x.
