I got a number of errors trying to compile GRASS 7 on the Mac last night.
Several have to do with something new in the GUI (for map swipe, modeler, and animation) that is choking on a 32/64 bit compilation that has worked fine before
The other has to do with GEOS. I DO have GEOS and configure reports it. But g.version complains that is is missing.
anthgradpc7:~ cmbarton$ cd /Users/Shared/grass_dev/grass7_dev/general/g.version
anthgradpc7:g.version cmbarton$
anthgradpc7:g.version cmbarton$ make
gcc -g -O2 -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.6.sdk -I/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/include -I/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/include -D_FILE_OFFSET_BITS=64 -I/Library/Frameworks/PROJ.framework/unix/include -I/Library/Frameworks/GDAL.framework/Versions/1.9/Headers -DGRASS_VERSION_NUMBER="‘7.0.svn’" -DGRASS_VERSION_DATE="‘2012’" -DGRASS_VERSION_SVN="‘54082M’" -DGRASS_VERSION_UPDATE_PKG="‘’" -DPACKAGE="“grassmods”" -I/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/include -I/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/include -o OBJ.x86_64-apple-darwin12.2.0/main.o -c main.c
main.c:31:20: error: geos_c.h: No such file or directory
main.c: In function ‘main’:
main.c:156: error: ‘GEOS_VERSION’ undeclared (first use in this function)
main.c:156: error: (Each undeclared identifier is reported only once
main.c:156: error: for each function it appears in.)
lipo: can’t figure out the architecture type of: /var/folders/dm/x_m7msz48xj_9c0059b59rf00000gn/T//cccW9YOx.out
make: *** [OBJ.x86_64-apple-darwin12.2.0/main.o] Error 1
Michael
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
Michael
______________________________
C. Michael Barton
USA
Michael
C. Michael Barton
C. Michael Barton
USA
I'll check and get back to you. Thanks for looking at it.
Michael
C. Michael Barton
USA
GRASS 7 now compiles g.version in the most recent revision. Thanks much.
Now to deal with the other modules that don't compile…
Michael
C. Michael Barton
USA
