I'm working on the GUI location manager and have run into a couple of irregularities in a couple of the projections parameters files. I'm sending this to the list instead of keeping it in the location wizard track ticket because they are a more general issue that will affect projection/location creation by other means too.
In proj-parms.table, the entry for "GEOS" is incorrect. There should be 3 subentries for each entry: projection code, projection description, and required parameters. However, GEOS is missing the projection description.
GEOS:HEIGH=ask,35800000.0;LON0=ask,20.0
The following entry has the correct format
GINS8:Ginsburg VIII (TsNIIGAiK):LAT0=ask,0.0;LON0=ask,20.0
GEOS is the only incorrect formatted entry in the file. It also is NOT in the datums.table file. So either it should be:
1) deleted from proj-parms.table, or
2) added to datums.table and a descriptive field added in proj-parms.table
Because it cannot be correctly parsed, I'll just skip it in the GUI location wizard. But if we are going to use this projection, it needs to be corrected in the 2 tables.
Also, in the proj-desc.table, several entries are incorrectly formatted. None of them are used by the proj-parms.table and so they probably should be removed from the proj-desc.table file. All are missing their description fields that are needed so that they can be read by a user. They are:
GUAM:bool:guam:
OALPHA:lat:o_alpha:
OLAT1:lat:o_lat_1:
OLAT2:lat:o_lat_2:
OLON1:lon:o_lon_1:
OLON2:lon:o_lon_2:
OLONC:lon:o_lon_c:
Michael
