I don't know what's going on, but I just tried to create a thematic map and
got the following error:
csh: if: Expression Syntax.
d.vect.thematic: awk required, please install awk or gawk first
I DO have awk installed (I double checked). I made no changes to the
d.vect.thematic script that should cause this error.
Does anyone have an idea what's going on?
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
From: Moritz Lennert <mlennert@club.worldonline.be>
Date: Mon, 11 Sep 2006 17:14:44 +0200
To: Michael Barton <michael.barton@asu.edu>
Subject: Re: added opacity option to grc fileMichael Barton wrote:
Moritz,
This will be nice if it doesn't break anything.
The optlist is used for a variety of things and was designed for options for
a d.* command. Opacity is not one of those options. It is a value used for
compositing when g.pnmcomp is run.I should look to see where optlist is being used again besides in creating a
list of options for *.grc output. But I'm assuming that it would be obvious
if this caused a problem.Let's hope. Sorry, I should have consulted you before committing.
I have another problem which is also new: it seems as if the thematic
layer only displays the highest (last) class. Below you see the messages
in the output window. Nothing seems to be going wrong, but in the
display I only see those areas which are in the range 4152.66 - 20174.Moritz
******output**************
Thematic map legend for column densite of map communes
Value range: 0 - 20174
Mapped by standard deviation units of 1747.52 (mean = 657.62)Color(R:G:B) Value
0:0:255 0 - 657.62
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file:
/home/mlennert/GRASS/DATA/BELGIQUE/mlennert/.tmp/geog-pc40/32172.0.ppm,
GRASS_WIDTH=642, GRASS_HEIGHT=482'vector/communes' was found in more mapsets (also found in mlennert).
85:0:170 657.62 - 2405.14 +1sd
170:0:85 2405.14 - 4152.66 +2sd
255:0:0 4152.66 - 20174
Michael
Arizona State Universityphone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbartonFrom: Moritz Lennert <mlennert@club.worldonline.be>
Date: Mon, 11 Sep 2006 12:13:09 +0200
Subject: added opacity option to grc fileHello Michael,
Just to inform you: I just added support for the opacity option in the
.grc file to cvs:http://grass.itc.it/pipermail/grass-commit/2006-September/024186.html
Moritz
