Hi coworkers
Now I have compiledand installed the grass-6.2.1 package with the
following instruction:
./configure --with-postgres-includes=/usr/local/pgsql/include
--with-postgres-libs=/usr/local/pgsql/lib --enable-64bit
--with-libs=/usr/lib64
the procedure don't show problems. However, when I try to execute
./r.example in /dist.x86_64-unknown-linux-gnu/bin the prompt shows:
sh: wish: command not found
I have tcl8.4 and tk8.4. when I execute "wish8.4" tk runs without
problems. I think that the problem is the grass isn't executing the
correct command, but I don'k know how to redir to wish8.4 instead wish.
Thanks
Juan
On Wed, May 30, 2007 at 05:39:19AM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > you have to run GRASS commands *inside* GRASS, means, that
> > you have to launch GRASS first. Then all paths will be
> > defined.
> To start the version of GRASS which has just been compiled, without
> having to install it, run "bin.i486-pc-linux-gnu/grass62".Hi Juan,
once you have it all working for you - please let us know where
and how to better document it!Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
