[GRASS-dev] Problems with wish
Agustin
I started grass with
[jdgiraldo@labitf08 ~]$ grass62
and the prompt shows
GRASS 6.2.1 (SENEGAL):~ >
I'm working in a Mapset called SENEGAL.
From here I access to r.example's directory:
GRASS 6.2.1 (SENEGAL):~ > cd grass-6.2.1/dist.x86_64-unknown-linux-gnu/bin
GRASS 6.2.1 (SENEGAL):~/grass-6.2.1/dist.x86_64-unknown-linux-gnu/bin >
and here I try to execute r.example:
./r.example
sh: wish: command not found
"ERROR"
Again, I think that grass doesn't call the suitable command (wish8.4
instead wish) but I don't know how (or where) redir the code.
Thanks
Juan
Juan,
You need to start grass before, something like ./grass.sh or simply
grass6, and once grass is started , you will see the following
GRASS 6.3.cvs (Projecte):/your path/ >
There is where you need to put r.example
Best
n May 30, 2007, at 1:06 PM, Juan Diego Giraldo Osorio wrote:
> Hi coworkers
> Now I have compiledand installed the grass-6.2.1 package with the
> following instruction:
> ./configure --with-postgres-includes=/usr/local/pgsql/include
> --with-postgres-libs=/usr/local/pgsql/lib --enable-64bit
> --with-libs=/usr/lib64
> the procedure don't show problems. However, when I try to execute
> ./r.example in /dist.x86_64-unknown-linux-gnu/bin the prompt shows:
> I have tcl8.4 and tk8.4. when I execute "wish8.4" tk runs without
> problems. I think that the problem is the grass isn't executing the
> correct command, but I don'k know how to redir to wish8.4 instead
> wish.
> Thanks
> Juan
>> On Wed, May 30, 2007 at 05:39:19AM +0100, Glynn Clements wrote:
>>> Markus Neteler wrote:
>>>> you have to run GRASS commands *inside* GRASS, means, that
>>>> you have to launch GRASS first. Then all paths will be
>>>> defined.
>>> To start the version of GRASS which has just been compiled, without
>>> having to install it, run "bin.i486-pc-linux-gnu/grass62".
>> Hi Juan,
>> once you have it all working for you - please let us know where
>> and how to better document it!
>> Markus
>> ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
>> ITC -> since 1 March 2007 Fondazione Bruno Kessler
> grass-dev mailing list
> grass-dev@grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
I believe if you set the GRASS_WISH environment variable before starting GRASS that could get around this for you.
E.g.:
export GRASS_WISH=wish8.4 (then start GRASS)
However, it also suggests that a link between wish8.4 and wish is missing on your system. On my linux and macosx systems, /usr/bin/wish is a symbolic link to /usr/bin/wish8.4
You could make the same thing with
sudo ln -s /usr/bin/wish8.4 /usr/bin/wish
(that's assuming your wish8.4 is in /usr/bin).
On 30-May-07, at 07:44 , Juan Diego Giraldo Osorio wrote:
Agustin
./r.example
"ERROR"
Thanks
Juan
Juan,
Best
Hi coworkers
wish.
Thanks
Juan
defined.
Hi Juan,
