hello,
I have several own modules which worked quit good but after the last cvs
update I receive either:
b7f8a000-b7f8c000 rw-p 00046000 03:03
1442615 /usr/local/grass-6.3.cvs/lib/libgrass_gis.6.3.cvs.so
b7f8c000-b7f90000 rw-p b7f8c000 00:00 0
b7f90000-b7f93000 r-xp 00000000 03:03
1442616 /usr/local/grass-6.3.cvs/lib/libgrass_stats.6.3.cvs.so
b7f93000-b7f94000 rw-p 00002000 03:03
b7f94000-b7f96000 rw-p b7f94000 00:00 0
b7f96000-b7fb2000 r-xp 00000000 03:03 932202 /lib/ld-2.6.1.so
b7fb2000-b7fb4000 rw-p 0001b000 03:03 932202 /lib/ld-2.6.1.so
bf7f5000-bf80b000 rw-p bf7f5000 00:00 0 [stack]
ffffe000-fffff000 r-xp 00000000 00:00 0 [vdso]
Abgebrochen
(terminated)
or
D3/5: region item: rows: 477
D3/5: region item: e-w resol: 30
D3/5: region item: n-s resol: 30
D3/5: region item: format: 0
D3/5: region item: compressed: 1
Loading Patches ... 100%
Performing operation distance ... 100%
Writing output ... D1/5: close tmp.NN.NN1.distance compressed
100%
Speicherzugriffsfehler
(memory access error)
I saw similar errors from g.copy a couple of weeks/months ago, but they were
solved with
make -C general/manage clean
make -C general/manage CFLAGS1='-g'
but that did not work for these modules.
I get this error only when I have a large input but before cvs update I
executed it successfully with > 100000 cells.
Any idea what changed in the last 8(?) weeks what might cause this error?
Sorry to be so unprecise - but I cannot tell when I updated the last time.
And if yes, how do I have to modify my modules so that they work again?
TIA, Martin
