GRASS Programmer's Manual for GRASS 7 [1] was not generated. It was
probably caused by @code tag without @endcode tag. This should be
fixed in r53078.
(This error appears only with the latest versions of Doxygen.)
Vaclav
fixed in r53078.
Vaclav
On Tue, Sep 4, 2012 at 12:37 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
I discovered some hanging jobs (never happened before).
Some hours ago I have rerun the prog-man generation, so it should
be updated now.
On grass.osgeo.org, Doxygen version 1.8.1.2 is installed. Needs to
be updated?
just as a random fyi, for recent stable packages of GRASS the programmers'
manual is available as a(n optional) package on ubuntu and debian systems,
in its HTML form:
http://packages.debian.org/grass-dev-doc
Hamish
be updated now.
I think that it is some Doxygen bug because this not happens with
older version I tried. I haven't discovered the circumstances when the
error happens, anyway, I've posted this to their ml [1]. They may be
more successful.
be updated?
I tried the latest (1.8.2) too but I got same error (hanging job). In
1.8.2 there are no changes which affect GRASS (C++11, Markdown) so no
special need for update.
Vaclav
