I’ve updated the programming manual (r58037), namely Command line parsing documentation in gislib.
I added some important things which were missing such as standard options. I changed some wording such as ‘parser routines’ which really scares me. I also changed the description of API in the way that it is object oriented as opposed to listing functions and structures separately.
I encourage every body to contribute to programming manual because it is crucial for attracting new developers. Well documented API can be more important than the quality of API itself.
Best,
Vaclav
== Details ==
The next step could be to move some details from API description to particular functions and structures and leave in the dox files only the main things combined with examples.
I haven’t touched the Complete Structure Members Table and Description of Complex Structure Members sections which requires another round of consideration.
Feel free to continue in my effort, correct English grammar or improve the documentation itself, e.g. with more current example.
You can compile the programming manual using
make htmldox
and than you can open a file
html/index.html
MarkusN, please, update the online version.
== Links ==
The old link is:
http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing
New links:
http://grass.osgeo.org/programming7/gislib_cmdline_parsing.html
Related source codes:
http://grass.osgeo.org/programming7/parser__standard__options_8c_source.html
http://grass.osgeo.org/programming7/parser__standard__options_8c.html
http://grass.osgeo.org/programming7/gis_8h.html
Change sets:
https://trac.osgeo.org/grass/changeset/58036 (mv)
https://trac.osgeo.org/grass/changeset/58037 (chnages)
Related GRASS Wiki pages:
http://grasswiki.osgeo.org/wiki/Module_command_line_parser
http://grasswiki.osgeo.org/wiki/GRASS_Programming_Howto
http://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library
(some of them are trying to substitute programming manual)
