forwarded from
https://lists.osgeo.org/pipermail/proj/2020-October/009839.html
I've now code ready to handle the update to EPSG v10
(https://github.com/OSGeo/PROJ/issues/2355). There are some backward
compatibility
challenges & risk assessment to do. See the cover text of
pull/2370 (targetted for 7.2) and
https://github.com/OSGeo/PROJ/pull/2371 (targetted for 8.0) for details.
It would be appreciated if downstream PROJ users could give a try at least
at #2370 to
confirm it doesn't break in major ways their apps.
And possibly also try #2371, but if your code inspects the details of
objects, like accessing
the datum of a CRS, be prepared for the dreaded datum ensemble concept to
show up (for
anything based on WGS84 and ETRS89), in which case you may need to use new
functions
added in the C API.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
