[GRASS-dev] PROJ problem compiling GRASS trunk
I just updated and tried to compile GRASS trunk. I also updated to the 2015-04-11 version of GDAL complete 1.11
When I tried compiling, I got the following error from /Users/cmbarton/grass_source/grass_trunk/lib/proj
urce/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/src/stlrnc.lla /Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/src/stpaul.lla
/Library/Frameworks/PROJ.framework/Programs/nad2bin < FL.lla /Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/FL
dyld: Library not loaded: /Users/Shared/src/proj.4/build-4.9.1/lion/usr/lib/libproj.9.dylib
Referenced from: /Library/Frameworks/PROJ.framework/Programs/nad2bin
Reason: image not found
/bin/sh: line 1: 65178 Trace/BPT trap: 5 /Library/Frameworks/PROJ.framework/Programs/nad2bin /Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/FL < FL.lla
make[1]: *** [/Users/cmbarton/grass_source/grass_trunk/dist.x86_64-apple-darwin14.3.0/etc/proj/nad/FL] Error 133
When I rolled back to the 2014-12 version of GDAL complete 1.11, it compiles fine.
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
Oops, the PROJ programs are still linked to my build. I'll fix it soon.
Michael
____________________
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
On Mon, May 18, 2015 at 8:49 PM, William Kyngesburye <woklist@kyngchaos.com>
I am not sure if this is related, but there is some problem with PROJ
programs not being on path. So when using m.proj which calls cs2cs, you get
an error from m.proj ("cs2cs program not found, install PROJ.4 first"). I
saw this on couple of computers which were using Michael's binaries.
Anna
< FL.lla
> make[1]: ***
Error 133
compiles fine.
> Michael
> C. Michael Barton
That is my duty."
- Tarzan, on war
I might have a hack to fix this. I add one of the programs to the path at compile time and could add the others too.
Michael
C. Michael Barton
On May 18, 2015, at 6:40 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
On Mon, May 18, 2015 at 8:49 PM, William Kyngesburye <woklist@kyngchaos.com> wrote:
Oops, the PROJ programs are still linked to my build. I’ll fix it soon.
I am not sure if this is related, but there is some problem with PROJ programs not being on path. So when using m.proj which calls cs2cs, you get an error from m.proj (“cs2cs program not found, install PROJ.4 first”). I saw this on couple of computers which were using Michael’s binaries.
Anna
Michael
C. Michael Barton
William Kyngesburye <kyngchaosatkyngchaosdotcom>
“We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty.”
“Don’t you even hate 'em?”
“What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn’t kill one ___ nor shorten the war one day.”
<Ha, ha> “And it might give 'em all stomach ulcers.”
  • Tarzan, on war
