fyi https://lists.osgeo.org/pipermail/proj/2019-May/008515.html
I have prepared candidates for the upcoming releases of PROJ 6.1.0 and
proj-datumgrid-europe-1.3.
Download the archives here:
https://download.osgeo.org/proj/proj-6.1.0RC1.tar.gz
(https://download.osgeo.org/proj/proj-6.1.0RC1.tar.gz.md5)
https://download.osgeo.org/proj/proj-6.1.0RC1.zip
(https://download.osgeo.org/proj/proj-6.1.0RC1.zip.md5)
https://download.osgeo.org/proj/proj-datumgrid-europe-1.3RC1.tar.gz
https://download.osgeo.org/proj/proj-datumgrid-europe-1.3RC1.zip
Please test the release candidates and report back any problems you may
find. If no issues
are discovered I plan to call the vote for promotion to final release on
Monday May 13th with
a targeted release date at May 15th.
/Kristian
from the included NEWS file:
Updates
o Include custom ellipsoid definitions from QGIS (#1337)
o Add "-k ellipsoid" option to projinfo (#1338)
o Make cs2cs support 4D coordinates (#1355)
o WKT2 parser: update to OGC 18-010r6 (#1360 #1366)
o Update internal version of googletest to v1.8.1 (#1361)
o Database update: EPSG v9.6.1, IGNF v3.0.3, ESRI 10.7.0
and add operation_version column (#1368)
o Add proj_normalize_for_visualization() that attempts to apply axis
ordering as used by most GIS applications and PROJ <6 (#1387)
o Added noop operation (#1391)
o Paths set by user take priority over PROJ_LIB for search paths (#1398)
o Reduced database size (#1438)
o add support for compoundCRS and concatenatedOperation named from
their components (#1441)
Bug fixes
o Have gie return non-zero code when file can't be opened (#1312)
o CMake cross-compilation fix (#1316)
o Use 1st eccentricity instead of 2nd eccentricity in Molodensky (#1324)
o Make sure to include grids when doing Geocentric to CompoundCRS with
nadgrids+geoidgrids transformations (#1326)
o Handle coordinates outside of bbox better (#1333)
o Enable system error messages in command line automatically in builds
(#1336)
o Make sure to install projinfo man page with CMake (#1347)
o Add data dir to pkg-config file proj.pc (#1348)
o Fix GCC 9 warning about useless std::move() (#1352)
o Grid related fixes (#1369)
o Make sure that ISO19111 C++ code sets pj_errno on errors (#1405)
o vgridshift: handle longitude wrap-around for grids with 360deg
longitude extent (#1429)
o proj/cs2cs: validate value of -f parameter to avoid potential crashes
(#1434)
o Many division by zero and similar bug fixes found by OSS Fuzz.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
