[GRASS-dev] [Proj] Update to EPSG database v8.8
FYI
---------- Forwarded message ----------
Date: Jan 13, 2016 11:57 AM
Subject: [Proj] Update to EPSG database v8.8
To: <gdal-dev@lists.osgeo.org>, <geotiff@lists.maptools.org>, <proj@lists.maptools.org>, <postgis-devel@lists.osgeo.org>
Cc: <qgis-developer@lists.osgeo.org>, <metacrs@lists.osgeo.org>
Just to inform you I’ve just completed the update to EPSG v8.8 (previous one
was v8.5) in GDAL trunk ( ​https://trac.osgeo.org/gdal/changeset/32964 ),
libgeotiff trunk ( ​https://trac.osgeo.org/geotiff/changeset/2714 ) and proj.4
master ( ​
https://github.com/OSGeo/proj.4/commit/832329a9aadbfcb7f46919c903f7672e719d2a82
). (and proposed PostGIS spatial_ref_sys.sql :
https://trac.osgeo.org/postgis/ticket/3427 )
As you can see (proj.4 nad/epsg file is probably the most readable to see the
diffs), It brings a bunch of new SRS, updated TOWGS84 shifts, etc…
Please report if you notice any issue.
Best regards,
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
Proj mailing list
Proj@lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
