In: https://lists.osgeo.org/pipermail/grass-stats/2021-April/001834.html
I draw attention to an issue raised with regard to the version of PROJ proj.db bundled with WinGRASS. Across the EPSG 9/10 border, table and field names change, so PROJ itself builds differently, and g.proj is built to handle the proj.db/EPSG version it "sees". If PROJ_LIB is changed to a different proj.db/EPSG version, obviously problems occur.
Is there a way to declare the EPSG version in g.proj, preferably before 7.8.6 ships? For now the work-around in rgrass7 is to trap the error found when g.proj expects EPSG 9 and is pointed at 10, and fall back from WKT2 to Proj4 string representation.
Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand@nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
