Dear lists,
[sorry for crossposting]
I have a strange problem regarding Oracle spatial datasets.
My dataset has the following projection:
Extent: (4452550.890000, 5324953.370000) - (4479484.079834,
5345694.049805) Layer SRS WKT:
PROJCS["GK Zone 4 (DHDN)",
GEOGCS[,
DATUM[,
SPHEROID["Bessel
1841",6377397.155,299.1528128],582.000000,105.000000,414.000000,-1.040000,-0.350000,3.080000,8.300000],
PRIMEM["Greenwich",0.000000], UNIT["Decimal
Degree",0.01745329251994330]], PROJECTION["Transverse Mercator"],
PARAMETER["Scale_Factor",1.000000],
PARAMETER["Central_Meridian",12.000000],
PARAMETER["False_Easting",4500000.000000],
UNIT["Meter",1.000000000000],
AUTHORITY["Oracle","82032"]]
[Columns follow here]
Note that the datum-parameter is empty.
I can "export" the data into shp using ogr2ogr which results in a shape
with the following proj-information:
Feature Count: 10584
GEOGCS[,
DATUM["Mean_Sea_Level",
SPHEROID["Bessel
Here you can see that the Datum now contains "Mean_Sea_Level". When
inspecting the written .prj-file from the shape I cannot find any entry
in the datum-parameters like "Mean_Sea_Level".
Is this the normal behaviour? I am asking, because GRASS segfaults
when using v.in.ogr with location=newloc parameter enabled.
I am using gdal-1.3.1, grass61 from todays CVS.
Currently out of ideas...
Thanks for your help.
Best
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
