Hello everyone,
My proposal:
I propose to develop a software to mine RSI images’ spectral bands including the visual,ultraviolet and infrared bands.This geospatial mining
will be done at bit level of bands to ensure maximum accuracy.If you look at the products available in the market they offer predictions
for the entire image instead I would allow users to choose customized areas to mine upon.
How this process would work?
**–>**This software can be used for multiple purposes like in case of Crop Yield production for farmers.
**–>**The software would need an event(RSI Image of Crop Yield of a geographical region X) and a contributing factor i.e. a factor that
contributes towards the success of the event like in this case it would be a RSI Image of rainfall of the same geographical region X.
**–>**After the inputs are fed,then a multimedia data mining algorithm would find a kind of mapping between rainfall and crop yield.
**–>**Once the mapping is found like Rainfall[ R<180,G>210,B<150 && B>125]–>Crop_yield[R>210,G>220,B<40] etc. then the farmer/user can
enter “n” such rainfall RSI images of different geographical images and the yields over there can be predicted.
Web application:
Once I was done with the development of codes.Then I thought of building the web application for my work and I uploaded the codes on
the server side and then those were executed using shell scripting in PHP.
Versions of packages:
- RGB–>RGB (1 Event and 1 contributing factor)
2.RGB–>GREY (1 Event and 1 contributing factor)
3.RGB–>RGB (One Event and 3 contributing factor)
Explanation of Codes on GITHUB:
parm11.java–>Converts RSI images into Band Sequential Format.
parm22.c–>Converts Band Sequential Format into bit Sequential Format.
parm33.c–>Generates Itemsets and rules using Peano count Tree association rule mining algorithm.
parm44.java–>Using rules and the input generates the predicted image.
Technical specifications : Java swings,C,PHP,HTML5,CSS3.
Hello everyone,
My proposal:
Web application:
Please provide feedback about the same.I want to add this feature to GRASS GIS.
Hello,
I cannot give you feedback for the actual proposal perhaps somebody else can. This relates to fact that you need somebody who is wiling to mentor this project.
Generally, as suggested at GSoC ideas page for GRASS GIS [1], you should show you interest and abilities by fixing some bugs. You can look for example at some bugs related to image processing (i.* modules) [2]. You can start to code your idea, however note that you should have something which is somehow complete and you can present and you don’t have much time.
Best,
Vaclav
[1] http://trac.osgeo.org/grass/wiki/GSoC/2015#Tipsforstudents
[2] http://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&component=Imagery&order=priority
On Mon, Mar 30, 2015 at 8:42 AM, Amitabh <amitabh.tiwari27@gmail.com> wrote:
Hello everyone,
My proposal:
Web application:
grass-dev mailing list
grass-dev@lists.osgeo.org
