[GRASS-dev] Proposal for setting up of new locations in wxGUI
I would like to suggest a modification (even for G6) for the
Location Wizard:
When defining a new location from an existing dataset (like SHAPE
or GeoTIFF with proper metadata), it creates the location and then
brings you back to the original startup screen, then you can "login"
into GRASS. But.. no maps there. So (new) users will be confused.
Change proposal:
Before reaching the startup screen again, ask if to import the map
which has been used for creating the location. Yes: do it; no: return
to startup screen.
What do you think?
2012/8/16 Markus Neteler <neteler@osgeo.org>:
to startup screen.
What do you think?
seems to be reasonable to me. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
I like it. It saves a step.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
Sent by: grass-dev-bounces@lists.osgeo.org
08/16/2012 10:56 AM
To
GRASS developers list <grass-dev@lists.osgeo.org>
cc
Subject
Location Wizard:
Change proposal:
to startup screen.
What do you think?
grass-dev mailing list
On Thu, Aug 16, 2012 at 4:55 PM, Markus Neteler <neteler@osgeo.org> wrote:
Location Wizard:
brings you back to the original startup screen, then you can “login”
into GRASS. But… no maps there. So (new) users will be confused.
Change proposal:
to startup screen.
What do you think?
+1 definitely.
Thanks!
Dr. Margherita Di Leo
