hi,
On Sun, Jan 07, 2007 at 08:07:30AM +0100, Martin Landa wrote:
I have prepared a new version of the patch where verbose mapping
instruction is removed. It will cause "ERROR: verbose : illegal
request" when the verbose mapping instruction is used.
On this place, I would vote for just a warning, so
+ /* Please, remove before GRASS 7 released */
if (KEY("verbose"))
- if (sscanf(data, "%d", &verbose) != 1) verbose = 2;
+ G_warning(_("verbose instruction was removed. Please use --verbose instead"));
continue;
Otherwise, tha patch looks good to me
Thank you
Jachym
Not sure if we can just remove this instruction...
Regards, Martin
2007/1/4, Martin Landa <landa.martin@gmail.com>:
>Hi Jachym,
>2007/1/3, Jachym Cepicky <jachym.cepicky@centrum.cz>:
>> Hi,
>> nice job, thanks for the patch, but when I'm thinking about it, ...
>> this patch makes ps.map set it's verbosity not by the --quiet
>> or --verbose flags, but also according to the input configuration file.
>Right, this patch allows to set verbosity level by the --q/v flag or
>by verbose mapping instruction.
>> imho, the simplest solution should be, remove the VERBOSE keyword from
>> ps.map. It would not harm to anythink. I doubt, some people are parsing
>Not sure, it would break backward compatibility. OK, maybe the verbose
>instruction should be removed later, now just printing appropriate
>warning about it. There is also question about priority: the --q/v
>flag should overwrite the mapping instruction or not?
>> output from ps.map in their scripts.
>> If so, G_set_verbose function is the best solution.
>> What do others think?
>> Jachym
>Thanks for the feedback Jachym.
>> On Tue, Dec 26, 2006 at 11:16:44AM +0100, Martin Landa wrote:
>> > Hi all,
>> > trying to change fprintf to G_message/warning/fatal_error in ps.map
>> > module I found one complication. There is a special mapping
>> > instruction --- VERBOSE. I think this instruction should overwrite
>> > GRASS_VERBOSE environment variable(??). There is also need to have a
>> > special function G_set_verbose() which allows to set a given verbosity
>> > level after first calling of G_verbose() fn. Please look at the patch
>> > (especially at verbose.c.diff). Thanks a lot.
>> > Best regards, Martin
>> > Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev@grass.itc.it
>> > http://grass.itc.it/mailman/listinfo/grass-dev
>> Jachym Cepicky
>> e-mail: jachym.cepicky@centrum.cz
>> URL: http://les-ejk.cz
>> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
>> OFFICE:
>> Department of Geoinformation Technologies
>> Zemedelska 3
>> 613 00, Brno
>> Czech Republick
>> e-mail: xcepicky@node.mendelu.cz
>> URL: http://mapserver.mendelu.cz
>> Tel.: +420 545 134 514
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.3 (GNU/Linux)
>> iD8DBQFFm97SyKt0uAjU4I8RAh4lAKCMce8cDJEO5Yf8Wra2msvgzAAfDwCfRraX
>> tGACE41v2F2Yv2UKt6AXuEI=
>> =2I9W
>> -----END PGP SIGNATURE-----
>Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
