[GRASS-dev] ps3.map: join two rasters
Jorge wrote:
Yes, but is more easy (and clean) add a option as 'gradient [y|N]' to
permit force gradient in CELL. I's a simple 'if' in the C code.
right.
> and the previous crappy work around here was to use r.mapcalc's
> r#map, g#map, b#map operators and patch the two maps for each band.
Well, but how do yo mask vectors?
I am not sure I understand. Do you want the raster map placed over top of
a vector area? Or vector area over the top but semi-transparent? or..?
Also, I try to understand your raster overlay method- can the background
raster retain its own color map or will it have to be monochrome? (with a
grey, blue, ... tinge)
Hamish
