This addon computes class proportions and majority class of a “cover layer” (e.g., a land cover map) according to how it intersects with areas/objects in a “base layer”. This function is similar to what r.stats.zonal performs, but is intended to be used on integer values raster (CELL type) instead.
This addon computes class proportions and majority class of a "cover layer" (e.g., a land cover map) according to how it intersects with areas/objects in a "base layer". This function is similar to what r.stats.zonal performs, but is intended to be used on integer values raster (CELL type) instead.
On Tue, Sep 24, 2019 at 8:05 AM tgrippa <Tais.Grippa@ulb.ac.be> wrote:
On Mon, Sep 23, 2019 at 4:09 PM Taïs <tgrippa@ulb.ac.be> wrote:
I noticed the table in the manual page looks terribly bad (https://grass.osgeo.org/grass76/manuals/addons/r.zonal.classes). I wasn't expecting that... What do you suggest: is it unnecessary and should be removed completely or should I make a print-screen of the attribute table and integrate it as an image ?
Not sure about image, how about simple ASCII in the <code> section?
