Hi!
Anyone that uses locally git and pushes changes directly to svn
(grass-addons)? Care to share some know-how?
I managed to get locally only sub-directories from the grass-addons svn
repository, via a series of svn commands (see:
<http://stackoverflow.com/a/50980/1172302>\).
For example, I did that for "r.sun.daily". I would like to push the
diff directly from my local gitted directory, not from inside the local
copy of grass-addons.
Thanks, Nikos
I committed something in the add-ons with the wrong description for the log and
something which was not my intention.
Is it enough to use something like
svn up -r ##### FileName
where #... is the revision number.
Thanks, Nikos
On Fri, Aug 14, 2015 at 11:06 PM, Nikos Alexandris
You find this documented here:
https://trac.osgeo.org/grass/wiki/HowToSVN#Revertingsubmittedchanges
Nikos:
> Is it enough to use something like...
Markus:
That's great. I'll fix my unintentional commits asap.
Nikos
ps- we have had a short discussion on keeping a complete local copy of
svn for having the options to move stuff around. Do you really, devs,
keep a complete local copy (>10GB)?
On Sat, Aug 15, 2015 at 8:17 AM, Nikos Alexandris
No need - there is the "svn copy" command for that. See e.g.
https://trac.osgeo.org/grass/wiki/HowToSVN#MovingmodulesbetweentrunkandAddonsrepository
I have checked out separately
grass64/
grass64_release/
grass65/
grass70/
grass70_release/
grass71/
grass-addons/grass-promo/
grass-sandbox/
and this is way less than 10 GB.
(the XX_release checkouts are redundant which I use to prepare the
releases - almost all file timestamps maintained which I try to
carefully keep since 1999 or earlier
