[GRASS-dev] PyGRASS: changing description and comments
is there a way of modifying the contents of the description and comments fields associated with rasters? I could also use r.support, but it would be more elegant to use the API.
Thank you.
Luís Moreira de Sousa
Bowlespark 8
6701 DN Wageningen
The Netherlands
Phone: +31 628 544 755
Email: luis.de.sousa@protonmail.ch
RingID: ring:7ca91d83f4f9dec82fec9f1144b8e5c1ef2a110c
URL: https://ldesousa.github.io
Sent with ProtonMail Secure Email.
Il giorno sab 10 nov 2018, 17:46 Luí­s Moreira de Sousa <luis.de.sousa@protonmail.ch> ha scritto:
Hi Luis,
It seems that description and comments are not possible to be modified by the API, other values instead are [0]
[0] https://grass.osgeo.org/grass70/manuals/libpython/pygrass.raster.html#module-pygrass.raster.history
Thank you.
Ciao
Luca
Hi Luis,
... grass70 is a bit dated, better:
https://grass.osgeo.org/grass74/manuals/libpython/pygrass.raster.html#module-pygrass.raster.history
even better
https://grass.osgeo.org/grass76/manuals/libpython/pygrass.raster.html#module-pygrass.raster.history
It will not change much but old API descriptions may lead to confusion.
