On Fri, Mar 1, 2013 at 6:50 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
For now, I would leave pygrass doc in the ReST (both the py and rst files).
That's fine. Martin and me have fixed the sphinx compilation, this now
works on more recent systems:
cd lib/python/pygrass/docs/
make html
It generates the nice Sphinx-based documentation.
I have updated the cronjob on grass.osgeo.org accordingly to obtain
http://grass.osgeo.org/programming7/pygrass/
but I struggle on the Debian Wheezy box with this error (maybe bad
sphinx installation there?):
Running Sphinx v1.2b3
loading translations [python]... not available for built-in messages
loading pickled environment... not yet created
building [html]: targets for 6 source files that are out of date
updating environment: 6 added, 0 changed, 0 removed
reading sources... [100%] vector
/home/neteler/grass7_svn_head_progmanual/grass7/lib/python/pygrass/docs/attributes.rst:113:
WARNING: autodoc: failed to import class u'Link' from module
u'pygrass.vector.table'; the following exception was raised:
File "/usr/local/lib/python2.6/dist-packages/Sphinx-1.2b3-py2.6.egg/sphinx/ext/autodoc.py",
line 335, in import_object
__import__(self.modname)
File "/home/neteler/grass7_svn_head_progmanual/grass7/dist.x86_64-unknown-linux-gnu/etc/python/grass/pygrass/__init__.py",
line 12, in <module>
from . import errors
File "/home/neteler/grass7_svn_head_progmanual/grass7/dist.x86_64-unknown-linux-gnu/etc/python/grass/pygrass/errors.py",
line 8, in <module>
from grass.pygrass.messages import get_msgr
line 13, in <module>
from . import gis
File "/home/neteler/grass7_svn_head_progmanual/grass7/dist.x86_64-unknown-linux-gnu/etc/python/grass/pygrass/gis/__init__.py",
line 23, in <module>
script.gisenv()
File "/home/neteler/grass7_svn_head_progmanual/grass7/dist.x86_64-unknown-linux-gnu/etc/python/grass/script/core.py",
line 979, in gisenv
s = read_command("g.gisenv", flags='n')
line 420, in read_command
ps = pipe_command(*args, **kwargs)
line 395, in pipe_command
return start_command(*args, **kwargs)
line 354, in start_command
return Popen(args, **popts)
line 64, in __init__
startupinfo, creationflags)
File "/usr/lib/python2.6/subprocess.py", line 623, in __init__
errread, errwrite)
File "/usr/lib/python2.6/subprocess.py", line 1141, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
Any ideas? On my Fedora 20 it works nicely.
thanks
