[GRASS-dev] Pygrass - Getting pixel infos from a raster map
I’m new to Grass and Grass development.
I’m writing a script using pygrass that should interact with areas in a raster map (output of i.segment). The final goal would be to highlight some of them to the user.
But I can’t even figure out how get infos from the different segments or even the raw pixels.
When instantiating a RasterSegment object (https://grass.osgeo.org/grass70/manuals/libpython/pygrass.raster.html#pygrass.raster.RasterSegment) and using the method .get(row, col) it gives me -2147483648 for .get(0,0) and other values for ‘row’ and ‘col’ give 0.
This doesn’t make any sense to me, am I missing something ?
(Note that both .exist() and .is_open() give True on the RasterSegment object)
Any help would be appreciated !
Lucas
The class pygrass.raster.RasterSegment is not directly related to the
output created by i.segment.
It is a class to allow random read and write access to very large
raster layers, that do not fit into the main memory.
Please use pygrass.raster.RasterRow[1] from grass7.2 for row-wise
access to raster maps.
Best regards
Soeren
[1] https://grass.osgeo.org/grass70/manuals/libpython/pygrass.raster.html#pygrass.raster.RasterRow
2017-03-14 20:18 GMT+01:00 Lucas lefevre <lucas.lefevre@hotmail.com>:
I'm new to Grass and Grass development.
I'm writing a script using pygrass that should interact with areas in a
But I can't even figure out how get infos from the different segments or
and other values for 'row' and 'col' give 0.
This doesn't make any sense to me, am I missing something ?
object)
Lucas
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
