And another question on GridModule:
For the same module using GridModule to split the task of edge detection in a raster map into many parallel tasks, when I want to stop the module run using Ctrl-C I get tons of
Process PoolWorker-315:
File "/usr/lib/python2.7/multiprocessing/process.py", line 267, in _bootstrap
self.run()
File "/usr/lib/python2.7/multiprocessing/process.py", line 114, in run
self._target(*self._args, **self._kwargs)
File "/usr/lib/python2.7/multiprocessing/pool.py", line 102, in worker
task = get()
File "/usr/lib/python2.7/multiprocessing/queues.py", line 374, in get
task = get()
racquire()
KeyboardInterrupt
and cannot stop the module, even when flooding the input with Ctrl-Cs.
Any hint how to allow Ctrl-C to stop all subprocesses ?
Moritz
* Moritz Lennert <mlennert@club.worldonline.be> [2018-03-08 15:05:46 +0100]:
self.run()
task = get()
task = get()
racquire()
KeyboardInterrupt
Moritz
Moritz, could it be a case related to the ones mentioned in
https://stackoverflow.com/a/1635084/1172302
https://stackoverflow.com/a/11816038/1172302
Nikos
Hi Nikos !
Am 9. März 2018 09:01:25 MEZ schrieb Nikos Alexandris <nik@nikosalexandris.net>:
+0100]:
_bootstrap
_bootstrap
self.run()
self.run()
run
run
worker
worker
task = get()
get
task = get()
get
racquire()
racquire()
KeyboardInterrupt
Moritz
Related yes, but AFAIU GridModule uses multiprocessing, not multithreading. I think it should be possible to modify something in the GridModule class so that it interrupts, but not sure about what exactly (apparently this is specifically a problem in Python 2. In Python 3 it should happen automatically IIUC.
Moritz
* Moritz Lennert <mlennert@club.worldonline.be> [2018-03-09 09:16:01 +0100]:
Hi Nikos !
+0100]:
_bootstrap
_bootstrap
self.run()
run
run
worker
worker
task = get()
get
task = get()
get
racquire()
KeyboardInterrupt
Moritz
Right. This https://stackoverflow.com/a/35134329/1172302 should be,
however, directly related. However, not portable, as per a comment.
How about this one: https://stackoverflow.com/a/44869451/1172302 (July
2017)? See
also
http://jessenoller.com/blog/2009/01/08/multiprocessingpool-and-keyboardinterrupt.
Nikos
If you can get their PIDs, you should be able to use os.setpgid() to
move them into the same process group as the main script. Ctrl-C (by
default) sends SIGINT to all processes in the foreground process
group.
