[GRASS-dev] pygrass: how to use GridModule with a module that has a 'width' parameter
I'm trying to run the i.zc module in parallel on several tiles. I use this syntax
     if options['tile_width']:
         parallel = True
         width = int(options['tile_width'])
         height = int(options['tile_height'])
         overlap = int(options['overlap'])
     processes = int(options['processes'])
kwargs = {'input' : inputraster,
           'output' : temp_edge_map,
           'width' : int(options['zc_width']),
           'threshold' : float(options['zc_threshold']),
           'quiet' : True}
if parallel:
    grd = GridModule('i.zc',
                     width=width,
                     height=height,
                     overlap=overlap,
                     processes=processes,
                     split=False,
                     **kwargs)
However, this fails (understandably) with
TypeError: type object got multiple values for keyword argument 'width'
Is there a way to work around this name conflict ? Do I have to define my own class derived from GridModule to change the parameter names ?
Moritz
No one for an answer to this one ?
On 06/03/18 14:59, Moritz Lennert wrote:
this syntax
          parallel = True
            'quiet' : True}
if parallel:
                      width=width,
                      height=height,
                      overlap=overlap,
                      split=False,
                      **kwargs)
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Tue, Mar 6, 2018 at 8:59 AM, Moritz Lennert <mlennert@club.worldonline.be
wrote:
syntax
        parallel = True
          'quiet' : True}
if parallel:
                    width=width,
                    height=height,
                    overlap=overlap,
                    split=False,
                    **kwargs)
Try `width_` instead of `width` for the module parameter. This is how
grass.script works (mostly to avoid conflicts with Python keywords namely
lambda), but without checking the code, I don't know if PyGRASS has this
implemented.
Vaclav
On 08/03/18 15:18, Vaclav Petras wrote:
On Tue, Mar 6, 2018 at 8:59 AM, Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
    use this syntax
      parallel = True
      'quiet' : True}
    if parallel:
      width=width,
      height=height,
      overlap=overlap,
      split=False,
      **kwargs)
    names ?
Try `width_` instead of `width` for the module parameter. This is how grass.script works (mostly to avoid conflicts with Python keywords namely lambda), but without checking the code, I don't know if PyGRASS has this implemented.
It doesn't. I tried width_ for both the i.zc parameter and the GridModule parameter. Neither were accepted as valid parameters.
Moritz
Dear Moritz,
On Thu, Mar 8, 2018 at 3:22 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Try width_ instead of width for the module parameter. This is how grass.script works (mostly to avoid conflicts with Python keywords namely lambda), but without checking the code, I don’t know if PyGRASS has this implemented.
It doesn’t. I tried width_ for both the i.zc parameter and the GridModule parameter. Neither were accepted as valid parameters.
I’ve modifiredt the Module class to support this in r72367 [0].
Let me know if fixed your problem,
all the best
Pietro
[0] https://trac.osgeo.org/grass/changeset/72367
Hi Pietro and greetings from the Bonn code sprint !
Le Fri, 16 Mar 2018 08:26:11 +0100,
Pietro <peter.zamb@gmail.com> a écrit :
Dear Moritz,
> how
I've modifiredt the Module class to support this in r72367 [0].
Yes, this fixes my problem. Thanks a lot !
Moritz
Le Sun, 18 Mar 2018 21:19:11 +0100,
> Dear Moritz,
> > how
> > parameters.
Maybe a candidate for backport to 7.4 ?
Moritz
On Sun, Mar 18, 2018 at 9:24 PM, Moritz Lennert
> Dear Moritz,
> > how
> > parameters.
For the (list) record, it has been done recently.
